Question about Pioneer TS-WX65A Car Speaker
How do you install front speakers on a 1999 olds. alero front speakers in the front doors do you pop off the speaker cover or do you have to take the whole door panel off?
    Problem Solver:
  • 16 Answers
Pop off speaker cover. there are screws you have to remove so you can replace your speakers....
Posted on Sep 08, 2009
Want to install a radio what wires are which
1999 Pontiac Grand Am Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size:
4? x 6? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size:
6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Mar 11, 2011 | 1999 Pontiac Grand Am GT
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Need to remove inside door panel on drivers side 1999 chevy silverado z-71 3 door new body style
just pop out the triangle piece from the top at the top front of the door panel with a flat head screwdriver. Then simply pop out the door lock cover from the aft side and the door handle cover from the aft side as well. Then pop up your cap containing the auto door locks and windows and disconnect the cannon plugs. Then just remove 2 screws (1 from under the door lock/window cap and one just insde the door handle itself. You'll then life up and towards you to remove the panel. Don't pull it too far out because you'll still need to disconnect the speaker cannon plug and pull out the door open light at the bottom aft of the panel. You can then set the door panel off to the side.
Jan 19, 2010 | 1999 Chevrolet Silverado 1500
How to remove and reinstall speakers in a 1999 Honda Accord
really simple process for the front doors. just remove the door panels and its self explainatory when you look at it. the rear speakers are a little more difficult. Use a flat head screw driver to pop off the speaker covers and use the correct size wrench to remove the screws. If you're putting in after market speakers, you will need to splice them. then just put everything back.
Aug 09, 2009 | 1999 Honda Accord
How to replace front speakers in a daewoo leganza 02
You will need to either remove the door card or the speaker grill on the door card. To do this you will need a set of thin nose pliers for removing door clips, a flat head screw driver and a phillips screw driver for any cross head screws. Use the flat head screw driver to pop the grill off, if the grill is not removeable you will have to take the whole door card off. To do this you need to remove the electric windows panel as well as the door handle and lock panel, from their disconnect them from their harnesses. Then remove all clips and screws holding the panel in place. The door card should come free without too much effort, pulling upwards and away from the window. Unscrew the old speakers and disconnect the wires from them. Wire your new speaker to the same wire configuration as the old one. Screw it in. Place the door card back on and then plug the harnesses back in and place the door lock and window locking panels back in place. Do the same for the other door.
A professional installation will cost about $80 I think, I did my door speakers on my car and all I had to do was pop out the grill so it was easier than I expected.
Jul 17, 2009 | Car Audio & Video
Change the speakers in a 2001 alero
You have to flip up the speaker cover, and loosen some screws from above. Then lift the speaker easly and reconnect the harness. Be carefully, it´s easy to breake the cover or scratch them...
Good luck to you
Feb 08, 2009 | 2001 Oldsmobile Alero
1999 Cavalier Speaker Removal
The rear speakers you need to take at least one side off. What I mean is the part when your sitting in the back seat the plastic piece were the armrest is. After you take at least one or both of these out just fold the seats down and the rear window carpet piece will have four plastic push pins then just pull it straight back and its out. After the carpet is out just unclip the speaker and pop it out then unplug the harness.
The front first you need to take the screw out of the small piece up by the side mirror and pull that piece out, then pull the metal clips for the window cranks, if you have manual windows. then the screws in the grab handles, the rest is just plastic clips. Just either get a specialty tool for this or I use a butter knife and slowly pry the door panel up and work it around the entir panel until its loose. sometimes no matter how hard you try to be carefull the clips will break though. They are failry cheap if they do and autozone should have them. after the panel is off it is pretty simple just take out the screws holding the speaker and pop it out then unplug the harness.
Jan 04, 2009 | 1999 Chevrolet Cavalier
How do you replace the front door speakers in a 1999 Model Hyundai Excel?
You have to take the door panels off.
The front speakers are 6"
So remove the front door panels, unbolt the factory speakers, bolt the new one in the existing holes, reinstall the door panels.
The grills will look factory, but you will have better speakers. Nice way to keep the good stuff hidden from prying eyes.
Oct 19, 2008 | 1994 Hyundai Excel
Radio wiring color codes
u need the colors of the radio or the car wires.... here are the car wires and the radio are below that. I suggest however gettiing a wiring kit..They are around 8 dollars and well worth the money. It makes is so easy to connect a radio.
RADIO 12V|orange + at radio
RADIO GROUND Black
RADIO SWITCH yellow
POWER ANTENNA dk. green at radio LF SPEAKER tan - gray at radio or LF speaker
RF SPEAKER lt. grn - dk. grn at radio or RF speaker LR SPEAKER brown - yellow at radio or LR speaker
RR SPEAKER dk. blu - lt. blu at radio or RR speaker
Radio wiring
constant power yellow
switched power red
power antenna/amp turn on blue
illumination is orange
all speakers the one with the black stripe is the negative connection.
right rear is purple
left rear is green
left front is white
right front is grey
hope that helps ya...
Aug 30, 2008 | 1999 Oldsmobile Alero
Drivers side window
Hi, callen
Look under the door pocket, you may find some deep recesses inside which are some securing screws.
Look around the handle which you use to pull the door shut, it may have screw covers which need to be popped out.
Look behind the door lever which you use to open the door, I think there may be a screw cover in there with a screw behind it.
And last but not least. if your door panel has one of those little tweeter speakers built into it as well as the main speaker, then pop the speaker out and you may find a screw behind there.
Very best regards
Geordie
Jun 20, 2008 | 1999 Volkswagen Passat
Pioneer TS-WX65A Car Speaker Logo
111 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
