After having trouble using an older YIM to login, I came back to 9.0... but am getting the same problem which caused me to attempt to revert to older builds...
Whenever i open a window to chat with someone on my list, i receive a script error!
approx details as follows:
Script Error on this page! Line: 7 Char: 2514 Error: Library not registered Code: 0 Url: ....Yahoo!/Messenge/pGReSw3zrMLtn4onkMpOxQ-- Continue Running Scripts on This Page? Yes/No
and despite which answer i chose it apparently is an error which disabled the scroll bar for my window! So when the text reaches the bottom it continues but i have no way of seeing it without restarting a new window! Is there a simple solution to remove this error?
(This is what i mean, sory, yahoo helper not helped much)After having trouble using an older YIM to login, I came back to 9.0... but am getting the same problem which caused me to attempt to revert to older builds...
Line: 7
Char: 2514
Code: 0
After having trouble using an older YIM to login, I came back to 9.0... but am getting the same problem which caused me to attempt to revert to older builds... Whenever i open a window to chat with someone on my list, i receive a script error! approx details as follows: Script Error on this page! Line: 7 Char: 2514 Error: Library not registered Code: 0 Url: ....Yahoo!/Messenge/pGReSw3zrMLtn4onkMpOxQ--
Continue Running Scripts on This Page? Yes/No and despite which answer i chose it apparently is an error which disabled the scroll bar for my window! So when the text reaches the bottom it continues but i have no way of seeing it without restarting a new window! Is there a simple solution to remove this error?
(This is what i mean, sory, yahoo helper not helped much)After having trouble using an older YIM to login, I came back to 9.0... but am getting the same problem which caused me to attempt to revert to older builds... Whenever i open a window to chat with someone on my list, i receive a script error! approx details as follows:
Line: 7
Char: 2514
Code: 0
when try8ing to read email the scroll bar is not there to scroll down the page can you help fix the problem when try8ing to read email the scroll bar is not there to scroll down the page can you help fix the problem
You can't post conmments that contain an email address.
hi again, sorry to hear you still having the problem.
Try uninstalling yim and reinstalling a fresh copy (make sure you restart the computer after the unistal). this might help as you might have some corrupt file that causes the error script that in it's turn affect the scrool bar somehow.
TekspotCoUK
TekspotCoUK
This happened to me...so I started to type friends names in the search bar just above the loading sybol and it loaded some friends to the page so i just selected all and it sent invites......hope this helps
The web cam works when you are online in YM or some other chat room. Look to the top of the YM when in chat mood. You will see "Invite to Web Cam" click on this and your cam should automaticly open
from the opening menu choose online and then either play now, or goto lobby. If you goto lobby choose lobby, (for starters pick my skill level) and then you can click on someones name and invite to a game, or if the invite you it will say so on the scrolling info bar at the bottom of the screen, thier name will also have a lightning bolt next to it if they invited you. click on them accept invite and try and win. my ID is dannmidge on the ps3 if you want to add me and we can play.
hallow
you are geting ths problem after updating your yahoo ,you can call your friends but not her
well the problem can be solved ,,the yahoo version which she is using maybe the older once and hence she is not able to call you or the call symbol is not there and you have the latest once
I, for one, appreciate your sincerity. I hope it is not false. There have been many different versions of YM over the years and most of them would probably work with the newest Operating System to some degree. Have you verified that you are using the latest YM as I suggest the Beta 9 version instead of the non-beta 8.1 version. My recommendations has more to do with security then anything else but since I KNOW that beta 9 works with my built-in webcam it would nice to know you are using a version of YM that I trust and use nearly 24 hours a day. By the way, when you de-install the old YM, kindly remove the Yahoo! folder ( delete the folder after the de-installation and before the re-installation of software ) located under program files as corrupted files can be left after the de-installatin that might and could affect your future re-installation of the software. If this is the only problem you can see, i.e. no other system problems, I will assume you have a clean computer ( one not infected by some virus, etc ) so just do as instructed above and get back to me please.
Line: 7
Char: 2514
Code: 0
Line: 7
Char: 2514
Code: 0
