Question about LG (CED-8080B) CD-RW Burner
Slave Jumper Position
I bought a CED-8080B LG CD-RW disk drive from garage sale and it didn't have any jumpers on it and i would like to know the slave position because right now it looks like this ::: and i want to know what to put it on because i have a reader in already but the writer in it is broken so i want to put this one in aswell so i can still have 2 in the computer
  • LG Master
  • 32,281 Answers
Most CD and DVD drives have markings showing the jumper positions for CS=cable select, SA=slave. MA=master. The jumper positions are either on a printer label or it is stamped on the metal case. The stamped markings are a bit difficult to see and are usually near the connectors.
Posted on Sep 08, 2009
    Guru:
  • 301 Answers
Ok......it is easy to do such, just place the jumper on the first : and enter the system setup them test if it is on slave if not repeat the same for all the ::::: untill you get the slave and cable select.
I have a LG CD-R?RW Drive CED-8080B/CED-8083B that has outdated software and reads burn process failed (power calibration error). I,m a beginner - don't know what this means. Need new drive? Update...
Sounds like you need to either update the firmware on the drive, or the drive is malfunctioning physically.
I'd just buy a new drive. Those things are very cheap now a days. Don't waste your time trying to fix it unless you can find an easy fix.
Feb 05, 2010 | Computers & Internet
After installing cd-rom i turned computer on and it says i need to change the stand alone slave drive master
I think that the problem here may be that the Jumper on the CD-ROM needs adjusting. The Jumper is a tiny piece of plastic at the rear of the hardware in question.
There will be a diagram on the top, or rear of the CD-ROM, with a choice of 3 settings. If it is a solitary Optical drive then place the Jumper in the 'C' position.
If it is a Slave, or secondary drive, then place the Jumper in the 'S' position & if it is a Primary or Master drive the it is to be placed in the 'M' position, respectively.
I hope that this sees an end to your dillema & lots of luck.
Kindest regards,
Ste
Jan 31, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
The jumper combination for a slave drive on an LG GSA-4163B
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
Nov 29, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
LG cdrw ced 8080b slave position
if the cd was set to secondery or slave on your motherboard usually it follows the hard drive on the tape or ribbon if you want to keep the cd as a master you will have to install a new ribbon and connect it to the secondary on the motherboard, motherboards have a primary where you can connect a harddrive and cd and then a secondery and do the same as long as you designate master and slave for each drive so as not to confuse the system later ones also have another option sata which gives you more options
Aug 22, 2009 | Computers & Internet
New CD R/RW drive will not let XP Boot
hi,
on the back of the new drive usually is a set of tiny pin jumpers, and a diagram for it on the drive, you might have to switch the pin jumper to "cs" cable select or "slave" usually master is for the hard drive. If that didnt do it then while the computer is booting hit f-8 or maybe f-9 and get into your bios area, search for boot sequence and study the area in there and see if your drives listed, try and change the config there so your hard drive(c) boots first, then usually your new drive. hopefully one of those ideas gets ya going, good luck
J
Jul 21, 2009 | LG CED 8083B CD-RW Burner
Compurt is not recognizing a new LG 22x Internal DVD rec
Change the Master/Slave/CableSelect(CS) jumper on the back of the drive (between the power connector and IDE cable)
STEP 1:
Check that the IDE cable red stripe goes to pin 1 (closest to power plug) flip cable if needed.
STEP 2:
Move Jumper to SLAVE position. reboot. check for drive in os. if it's not there;
STEP 3:
Move Jumper to MASTER position. reboot.
If it's still not working replace your IDE cable and try again
Jun 20, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Plug up a DVD ROm
To a desktop computer?
Depending on the connectors you either have a 4pin power connector and a 40pin ide connector.
you should have both of those on all desktop computers.
the drive could also have those flat connectors, then you would need a SATA power connector and a SATA data cable.
if your motherboard doesn't have a SATA connector then you need to get a Pci - sata card http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pci+sata
that will give you the sata data connectors. then you need sata power for it if your computer doesn't have a flat power connector then you need to purchase a converter. http://www.newegg.com/Product/Product.aspx?Item=N82E16812189005
the drive wont need anything else, just plug it in and it should work. remember when working inside the computer always unplug all cables.
if you use the 40pin connector then you might need to check on a jumper setting incase the drive doesn't work, you can read the jumper settings on top of the drive, and on the back of the drive you should have 6 pins close to the 40pin connector, there should be a small plastic / inside metal connector jumper, set it to the correct position, master or slave, if there is another device connected in the ide cable then set it to slave. if it doesn't work that way then set it to master.
if it doesn't work on either one, then get someone to look at it.
May 26, 2009 | LG GCC 4520B CD-RW/DVD-ROM Burner
My computer is not detecting my drive no installing options displayed.
Follow these simple steps..
>Check for the jumper on your Hard Disk. Jumper is nothing but a black colored small pin which is fixed on the rear side of your HDD.
Make sure it is at first slot.If not, change it.
>Now remove the jumper of your drive.(Drive doesnt need a jumper).Now your drive acts as slave and HDD as master.
>start your computer and check for the icon in MY COMPUTER.
This should solve your problem.
Apr 05, 2009 | LG SecurDisc 20x External Double-Layer DVD...
JUMPER SETTINGS
The settings are pretty much universal, This comes from memory:
there are 6 pins
s m c
l
So you connect the first 2 pins. shown as .l.
If my memory is incorrect then try the middle one
if that doesnt work try the last possible combo.
trial and error my friend :) You can do it.
Feb 13, 2008 | LG CED 8083B CD-RW Burner
LG (CED-8080B) CD-RW Burner Logo
256 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
