Question about Nokia E51 Cellular Phone
E51 bluetooth connection handsfree problem
My bluetooth connection with my Parrot handsfree car kit worked fine for 3 months. Since a few weeks my E51 drops the connection after 20 sec. Setups were not changed and other mobile phones work fine with the Parrot kit. My E51 has a similar problem with my wife's Parrot kit. So I'm pretty sure the problem is related to my mobile and not the handsfree kit.
Thank you for any advice!
Peter
Recently I replaced the battery on the steering control part of my parrot kit and it worked well for two months but now I have a blank screen on the visual display. What would have caused this ?
It sounds like the kit has had a software freeze, you will need to remove power from the Parrot Blue box and replace, if this works then I would also perform a software update.
Nov 26, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
My parrot mki9200 does not turn on i press all the buttons but still does not turn on please help me solve the problem
I had the same problem. stopped turning on one fine day after a little more than a week of installing. then started working again after a few months. realized that it turned on when i thought i had lost it for good. then i also realized that the other instruments in my car were reset, like clock, radio etc. then realized that someone had removed the batteries and installed it again. the clocks restart when you do that. then i realized thats what must've worked and i was right. keeps 'not turning on' from time to time nowadays as well. but works every time i disconnect the batteries and connect them again. like restarting it. hope it works for you too...
May 06, 2011 | Parrot SA Parrot MKi9200 Advanced Color...
Will not connect to my sonyericsson w995
i checked that your phone is compatible wd the parrot handsfree bluetooth.
turn-on your bluetooth of your phone
turn on bluetooth of your parrot handsfree see manual where the buton is located
From the phone:
* Go to MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / MY DEVICES / NEW DEVICE
* Phone will search for available bluetooth devices
* Select Parrot Product from the list
* Enter Passcode "1234" and go to OK
* Accept the pop-up
* Devices are now paired and connected
fleche.gifSending contacts via Bluetooth
Jan 29, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Wire connection
try doing a web search for part number 86117 this is a Kram teleom part number to adapt you car to a parrot.
DAN
Feb 21, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
The parrot comes up with memory full when I
try holding the 2 bottons in for 1 min to reset the kit, if this doesnt work it will have to be replaced
Jan 12, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot V5 10C device tells me memory full when trying to pair
The unit can only hold 3 phones in memory. Hold down the answer and hang up buttons together for 2 or 3 seconds and you'll hear a voice telling you memory is being erased. It's ready for 3 more phones again.
Aug 24, 2009 | Parrot Par Ck3000 Evolution Ck3000...
Nokia E51 Cellular Phone Logo
374 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
