Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer won't agitate/spin
The Washer won't run (agitate or spin) unless the lid is slammed pretty hard. I'm assuming the lid switch (washer lid must be closed to operate) is the problem but have no idea where it is at.
    President:
  • 1,776 Answers
Check out the video at the link that I'm attaching and see if it leads you in the right direction toward changing the lid switch. The switch should be checked for loose/corroded electrical connections and checked for continuity using a multimeter or ohmmeter. A lack of continuity means a bad switch. If bad it will have to be replaced, Sorry for your trouble and I hope this helps. Best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 08, 2009
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
When i close the led hard it works why?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the machine will neither wash nor drain/spin unless you "slam" the lid, the problem points to a loose / damaged Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Oct 12, 2010 | Kenmore 15864/15862 Top Load Washer
My kenmore series 80 wont drain it agitates but stops when it is time to drain md#23822100 sr#CM3908062
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23822100&pathTaken=partSearch
I'm assuming that it will neither drain NOR spin.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 19, 2010 | Kenmore Washing Machines
No Spin Cycle in Kenmore 80 Series Top Loading Washer
First, see the Sears parts site for your washer: Following is the Sears site for Whirlpool (110.) models with your model number.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23812100
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
Series 80 kenmore washer, agitates but won't drain or spin
Hi, There is a good chance the lid switch is going bad. When in the spin cycle, does the motor run at all? If the motor does notrun, you will need to test the lid switch first.
Please get me a model# so I can look this model up.
Thanks
Vic
Jun 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
you need to check the lid switch, does it click. you can unplug and then remove the 2 screws to see it, if it looks like it is coming apart then the lid switch is bad. you can buy one for about $40 or so dollars. i am assuming it doesn't spin either.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
386 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
