What is the benefit of using 6 row coil over 4 row coil in evaporators
  • 396 Answers
Cooling compacity only.
Posted on Sep 08, 2009
Whats the correct firing order on a 1999 honda accord ex coupe v6
Assuming it's the 2.7 litre, the firing order is- 1, 4, 2, 5, 3, 6.
The coil pack/distributor is turning ANTI clockwise. The cylinders are numbered from left TO right, as follows. The back row is 1, 2, 3, and the front row is 4, 5, 6.
May 15, 2018 | Honda Cars & Trucks
Some one please tell me how to get the plugs right on 2001 mercury moutaineer on the coil
The firing order is 1-4-2-5-3-6. But on the coil they should be in this order: 1-2-3 on back row, and 5-6-4 on front row. Standing from in front of car facing engine compartment, going from passengers side to drivers side. Hope that makes sense.
Kip. Martin, service manager at a Ford dealership.
Jan 30, 2015 | Mercury Cars & Trucks
2003 ford windstar spark plug wires diagram
I\'m assuming you have the 3.8 engine,although i believe the firing order is the same on all there v6 sideways mounted front wheel drive Windstars. That firing order is 1-4-2-5-3-6, with 1-2-3 going from left to right on the back side of the engine and 4-5-6 left to right on the front side of the engine.Looking straight down at the coil from the front of the car,you\'ll see 2 rows of coil terminals.The row on the right side is 1-2-3 going from top to bottom,row on left side is 6-5-4 going from top to bottom. Hook the number 1 coil terminal to the number 1 spark plug ,being careful to use the spark plug wire that is closest in length to the length you need. If your just replacing wires,yuo shouldn\'t have to much trouble. If your nreplacing the spark plugs you will find the ones in the rear,especially the number 2 [the middle one} are pretty difficult without removing the cowling. A total pain brought to you by the designers at Ford!
Jun 04, 2014 | 1998 Ford Windstar
Need plug wiring diagram for 2001 ford widsrtar
The rear cylinders are from passenger to drivers side 1-2-3 The front cylinders are 4-5-6 The coil as you standing in front of the vehicle will be Back row from passenger to driver side 4-6-5 Front row 3-2-1 Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Oct 23, 2011 | 2001 Ford Windstar
Game 100 professor layton and the curious village please solve
Most of the squares you make will be tilted 45 degrees to the side, and their sizes will vary as well.
Start by looking for pins you can connect to create squares at a diagonal. Hint 02 You want more specifics? All right, here's the location of one of the squares. Connect the four pins in the top-left corner to form a tiny square.
Just so you know, this is the only square on the board that isn't tilted. Hint 03 The largest square contains the pin that's third from the top on the left column and the bottom pin from the far-right column.
You also need to form a small diagonal block using the two pins lined up diagonally on the bottom-left portion of the board. There are two more small squares just like this one on the board. Solution For square 1, use pins 1 and 2 from row 1, and pins 1 and 2 from row 2.
Square 2 uses pin 1 from row 4, pins 1 and 3 from row 5 and pin 1 from row 6.
Square 3 has pin 3 from row 3, pins 2 and 4 from row 4 and pin 4 from row 5.
Square 4 is formed with pin 5 from row 1, pins 4 and 6 from row 2 and pin 4 in row 3.
Square 5 involves pin 3 from row 1, pin 5 in row 2, pin 2 in row 3 and pin 3 in row 4.
Square 6 has pin 3 in row 2, pin 5 in row 3, pin 2 in row 5 and pin 3 in row 6.
Square 7 uses pin 4 in row 1, pin 1 in row 3, pin 5 from row 4 and pin 2 in row 6.
May 31, 2011 | Nintendo Professor Layton & the Curious...
Help with Curious Village game on Nintendo DS
Hi Gill
Hope this helps and good luck!
Scott
Mar 25, 2010 | Nintendo DS Console
Ford engine firing order v6
V6 Cylinder numbering:
1 - 2 - 3
4 - 5 - 6
(Front of Vehicle)
The coil pack looks like this
--4 pin--
--1--- 2--- 3--
--5--- 6--- 4--
----------------- Coil: with the connector positioned in the lower right hand corner, the upper row from left to right is: 4-6-5. The lower row is 3-2-1.
Oct 13, 2009 | 1999 Ford Taurus
What is the firing order for a 1997 Ford Taurus.
2.5L Engine: 1-3-4-2
V6 3.0, 3.8: 1-4-2-5-3-6
Taurus SHO V-8: 1-5-4-2-6-3-7-8
1 - 2 - 3
4 - 5 - 6
(Front of Vehicle)
--4 pin--
--1--- 2--- 3--
--5--- 6--- 4--
Sep 03, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
FIRING ORDER FOR 2003 TAURUS V-6 AND PLUG WIRE LOCATION
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 10, 2009 | 2000 Ford Taurus
I can get 7 squares but I'm told it's wrong
SQUARE 1.= use pins 1 and 2 from row 1 and pins 1 and 2 from row 2!
SQUARE 2= use pins1 from row 4 , pins 1 and 3 from row 5 and pin1 from row 6
SQUARE 3= use pin 3 from row 3 , pins 2 and 4 from row 4 and pin 4 from row 5
SQUARE 4= use pin 5 from row 1 , pins 4 and 6 from row 2 and pin 4 in row 5
SQUARE 5= use pin 3 from row 1 , pin 5 in row 2 , pin 2 in row 3 and pin 3 in row 4
SQUARE 6= use pin3 in row 2 , pin 5 in row 3 , pin 2 in row 5 and pin 3 in row 6
SQUARE 7= use pin 4 in row 1 ,pin 1 in row 3 , pin 5 in row 4 and pin 2 in row 6.
Feb 24, 2009 | Nintendo Professor Layton & the Curious...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
