Question about Goodman CPLE24-1 Air Conditioner
Fan & Heat Runs Constantly and Will not turn off
Unit is in constant heating mode when power is applied and no matter what the settings are on the thermostat. (Also includes thermostat removed)
  • 1 more comment
  • Anonymous Jan 07, 2008
    the out side heating unit is frezing over the heat pumps coils.
  • SatelliteDad Feb 04, 2008
    Thankyou all for trying.
    After investigating the wiring schematics further and testing with my multimeter, my suspicions were confirmed. The problem was related to a bad relay, which controls the heat strips in the Air Handler. The relay had failed in the closed (energized) position. Normally, this relay gets energized by 24v DC when the thermostat is in heat mode and needs to increase temperature. Failure in the closed position applies power to the heat strips and the blower constantly. The blower running is obviously a safety precaution to prevent possible combustion from no air moving over the heat strips.
  • gooch62 Jan 06, 2009
    It seems like I have a problem similar to yours. Except, my heater strip comes on every now and then. It will stay off for a while and then it will stay on for a while even if the thermostat is set to off or disconnected.
Low on freon
Posted on Feb 02, 2008
    Problem Solver:
  • 15 Answers
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
My HP Pavilion dv6 WW146AV runs hot!
In order to address this the unit must be taken apart, remove fan and clean with compressed air, next remove the heat sink, four spring loaded screws turn one "small amount" go diaganal do the same and the next two until removed from the processor ic, blow out any dirt, next remove old silicon grease with rubbing alcohol, apply fresh thermal grease to the ic and heat sink "small amount" and assemble.This will solve most issues.
Mar 05, 2012 | HEWLETT-PACKARD Computers & Internet
This is a Unico AIR HANDLER in a residential application with heat / cool unit in the attic. With system off (not calling for cool) and fan in auto mode, the blower fan is on high speed only constantly....
Sounds like a sticking relay. You can check the stat simply by remove the faceplate. If fan still runs with tstat cover off its not the stat. Not sure is your blower has a separate relay or if relay is mounted on control board. This can be bypassed with a new relay if you are willing. Good luck!!
Mar 26, 2017 | Heating & Cooling
My pc fans runs constantly and the computer is hot
There are several things to look for here.
  • The CPU Heat sink (the big metal block with a fan) may not be making good contact with the CPU surface area.
  • Thermal compound may have not been applied between the CPU surface area and heat sink
  • The heat sink and fan are not sufficient enough to cool your CPU
  • Dust buildup is not allowing proper circulation of cooling air
If this system is not a name brand and covered by warranty then I would remove the heat sink (carefully) and verify that the mounting bracket is not broken or loose. I would check that ample thermal compound is applied, and if not use rubbing alcohol to remove all compound from the heat sink and CPU and purchase a tube of compound to apply yourself. I would also thoroughly clean the heat sink with compressed air.
If the heat issue continues then you will want to consider upgrading to a more powerful cooling solution.
The CPU fan should run constantly but in some systems will run between 50% and 100% speeds assuming a variable temperature control is applied to the system via motherboard or third party installation.
Sep 06, 2011 | Computers & Internet
How do you turn on the heater?
Mine has two switches one says cool - off - heat, the other says fan on - fan auto. For heat I set the first to heat and the second to auto. This puts everything in to heat mode and the fan runs from the furnace control now not constantly. Hope this helps you out.
Dec 28, 2010 | Honeywell TH4210D1005 Heater
My outside fan will not run and the inside unit runs constantly. can't push the reset button on unit outside
Your out door unit fan motor not runs due to pressure not build up at Heat mode. If its cool mode only fan runs with compressor when thermostat calls for it.
Without having technical knowledge, don't press any reset button. Hope it's helpful?
Dec 09, 2010 | Ruud Central System Air Conditioner
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
232 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
