Question about Optoma EzPro 739 Multimedia Projector
No Power My Projector has no power. Worked fine, replaced bulb, plugged it back in, no power. Plug works and power cord is plugged in securely. No lights nothing. Thanks.
  • 2 more comments
  • squatdeluxe Dec 25, 2007
    I also have the same problem. I opened the optoma to clean it, took out the lamp and put it back and i got no power ...
  • SupaLuke Jun 15, 2008
    I have the same problem. Unit was overheating, so I took it apart to remove all the dust that had built up and after putting it back together... Nothing! No power what so ever. Please advise.
  • Anonymous Mar 14, 2009
    Mhmmm, I too cleaned mine out because of overheating and had power problems, after leaving it pluged in for a while it finally turned on, now I can turn it on but it shuts off after a few minutes without any warning. HELP
  • Pedro Bonilla Sep 26, 2013
    make sure the lamp cover is placed properly and that a small perturing flap on the cover enters thru a slot in the lamp housing to make contact with the interlock switch located there undernieth the lamp housing, if still check the conection to the switch board located on top cover of projector,the wire expose are on flat cable point to base the blue part away from base. good luck
Wow i have the same problem and no one has a fix love it
Posted on Sep 22, 2008
    Check the lamp cover, theres an interlock switch that the cover makes contact with small flap the enters into the lamp body
Me too anyone find a fix?
Posted on Jan 19, 2008
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
InFocus LP 250 Multimedia Projector was working fine until i unplugged it and when I went to plug it back in, I used my computers power cord instead of the projector but the plug is almost identical. I...
The plugs on this model projector is very delicate, over time the solder around the plug will begin to crack. Until eventually the connection is lost. Another possibility is that the power supply has gone bad. Using another cord would not cause this. I can fix the projector if you'd like. My ebay screenname is gtitubro.
May 11, 2010 | InFocus LP 250 Multimedia Projector
Power on, no light...worked in the test run
can you enter the setting and check bulb life timer and if you can reset it?
please feeb back
Apr 18, 2010 | Optoma EZPro 719 DLP Projector
Projector not booting up
The projector may not be receiving power or it may be malfunctioning. Turn the projector off and unplug the power cord. Confirm the power cord is securely connected to the projector and then plug the cord back in to a different outlet and turn on the projector. If this does not solve the problem, and another light is on or flashing, check the projector’s status.
Hope this helps
Apr 01, 2010 | InFocus IN24 Multimedia Projector
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Infocus 250 projector won't power up
Urinate on the bulb. This sometimes lubricates the contraption that the bulb connects with and it usually comes on instantly.
Mar 23, 2008 | Office Equipment & Supplies
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
260 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
