Port 80 - Computers & Internet
    President:
  • 2,022 Answers
Port 80 is use for internet browsing.
Posted on Sep 08, 2009
HOW DO i BLOCK PORT 80
Port 80 is the web port. Whenever you look at a web page you are going to port 80 on the server. If you block port 80 then you won't see web pages. I am assuming it's outgoing traffic to web servers you wish to block. A standard router will have incoming port 80 blocked by default. You would OPEN port 80 if you had a web server at home.
Feb 22, 2015 | Apache Micro Peripherals Computers &...
Port 80
You need to login to the router, and enable "port-forwarding" so that incoming traffic (80/TCP) is redirected to the ONE computer on your private network that is running a web-server that is "listening" on 80/TCP.
Jul 25, 2012 | Linksys WRT120N Wireless-N Home Router,...
Enabling port 80 access
You will have to go into the main page of your router, type 192.168.0.1 or 192.168.1.1 in your address bar of your web browser.
When you log in look for an option that says "Port Forwarding". In this page you will have to enter the port you want to open (80) and then type the IP address of the computer you want to receive the port 80 requests.
****PLEASE NOTE: If you are trying to open port 80 on a residential account, CALL YOUR ISP first and verify this is possible!
Why?
Port 80 is an internet port. People who use this port generally do stuff such as hosting a website. Most ISP's block port 80 for residential customers because they do not want them having that kind of traffic coming in. If that is the case, there will be no way for you to open the port. You will either have to use a different port, or upgrade to a business account. Just an FYI so you don't go crazy!
Oct 23, 2009 | Belkin N1 Vision Wireless Router
I have a zyxel p600 series modem connected to a Belkin wireless router. I am trying to run a web server on port 80. The modem was using port 80 for access to the internal settings. I changed that to...
Your setup looks correct to me. It might very well be that your ISP is blocking port 80. Go here and check from your server if port 80 is accessible.
If you are the only one that wants to connect to you server, you can simply choose another port to use, i.e. www.myserver.com:801. Set port forwarding form port 80 to 801 in your router.
TCP&UDP - from 801 - to 80 - [serverIP] - [Webserver]
The better way is to use a service like DynDNS.com or No-IP.com. You can register a DNS name (like myserver.dyn.com), which redirects to your public IP. The trick is to update your IP address, so even if you have a dynamic IP assigned from your ISP, the redirect will point always to your server. Most routers have the ability to set up with DynDNS, so the process runs in the background and you don't have to update manually - check your router manual.
The second part of this beauty is the redirect to a different port. So even if your port 80 (and 25 for that matter) are blocked, you don't have to have an arbitrary number in your URL (http;//myserver.com:801). You can find more detailed information here.
For a quick check, change your webserver to run on port 801, enter the redirect in your router and see if you can get to your server from the outside (internet). If you still can't access the webserver, the problem is not a blocked port.
Hope this helps, but if you have any more questions, just come back here and leave a comment - I'm happy to help you figuring this out.
Oct 23, 2009 | Computers & Internet
Open port 80 on Netgear GG843
By default port 80 on the router is already open.
Jun 14, 2009 | NetGear DG834 Router
My you tube dont work
Go to Start > Control Panel > Windows Firewall> Exceptions> Click on add port.
Call it port 80.
In port number type in 80.
Then click on OK.
Then close all the windows.
Basically on the computer that is running apache (Server), YouTube is unblocking the port called 80. On some systems mainly XP home we found that port 80 was always blocked. Even though localhost worked, computers connecting to it would get an connection error. Also, if you have a 3rd party firewall, you have to unblock YouTube. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
I cant open youtube
Call it port 80.
Then click on OK.
Thanks, Joe
Mar 08, 2009 | Intel Pentum 4 3.2Ghz System (SYP32) PC...
Port forwarding?
You can follow the steps on this link, click here. This is the steps on how to setup port forwarding for pc anywhere on a DFL-200. There is big possibility that the DFL-80 might have the setup configuration page as the DFL-200.
I hope this one helps.
Jul 07, 2008 | D-Link DFL 80 (DFL-80) Firewall
I have tried to setup the firewal to accept access for port 80
Some ISP's block port 80, the problem is not the firewall, following the procedure as described on d-link website should do it. If the problem is really the ISP, you have two choices:
Switching to a plan that allows you to use port 80.
Use port 8080, as alternate web port. The disadvantage is that acess will require http://ipadress:8080
Feb 07, 2008 | D-Link DFL-800 Firewall
Web Server Crashes on port 80.
A couple of questions for you...
1) What do you mean by 'crash'? How do you know its crashed?
2) Can you look in the Windows Event Viewer to see if there are any warning/error messages in the Application or System logs around the time of the starting or crashing of your web site on port 80? If so, anything that suggests the issue. If you don't understand the errors, try posting some of them here.
3) Is there any other web server running on port 80? If your running Internet Information Server, open the Internet Information Server Manager (mmc) console and click on "Web Sites" and it should list all the sites in the right pane. If you have anything 'running' on port 80, it will conflict.
4) Are you running Apache or any other web server on the system? If so, you're going to need to look at those configurations as well.
5) How about any other applications that might have a built in web server?
Let me know.
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
