Question about Epson Dot Matrix LQ-300+ Printer
RIBBON BECOMES LAX AS ALSO SLIPS OUT OF HEAD AND STOPS PRINTING ALTOGETHER. PRINTER LQ 300 +
    President:
  • Epson Master
  • 2,017 Answers
Make sure the ribbon you use it is genuine epson ribbon. and also adjust the liver by keeping 4 point .
Posted on Sep 08, 2009
My problem is the ribbon always comes out from the slot... how to fix it???
1-when install your ribbon push it to fit its proper place,
2-make a proper distance between head and paper using Head adjuster lever .
Feb 11, 2014 | Epson Dot Matrix LQ-300+II Printer
Problem
carriage home sensor (near ribbon drive assy) may defective
Jul 26, 2013 | Epson Dot Matrix LQ-300+II Printer
LQ 300 +2 auto pause during printing
This is a feature provided by the manufacture to protect the print head overheat for small dot matrix printers. Here giving printer head connection diagram, the last two row have temperature sensing (thermister) connection pin 1 to 1. If the thermister is faulty in the print head the printer will auto pause abnormally. Check the printer with compatible / EPSON recommended print head. These kind of small printer only for POS printing not for continues printing. 2_17_2012_8_31_04_am.jpg
Feb 16, 2012 | Epson Dot Matrix LQ-300+II Printer
My LQ 1070+ prints light as though the ribbon is worn out. However, I have tried new ribbons and it does not darken. Do I need a new printhead? If so, where can I buy one and/or what is the price? I am...
There is an adjustment which moves the printhead closed to the paper. Try adjusting that. Also check that your ribbon is transporting correctly and the the head is not printing on one spot of the ribbon too long.
Jan 22, 2011 | Epson LQ 1070+ Matrix Printer
Hai my printer epson lq 300 + printing issue zigzag kindly solve this issue
Hello This condition of Dot Matrix printer only due to
1. Bad ribbon cartridge (25%) 2. faulty print head (75%)
First replace your ribbon cartridge and try printing, if not OK then you have to replace the print head.
Good Luck
Jan 08, 2011 | Epson LQ 300+ Matrix Printer
I have an LQ Epson printer which has refused to print it passes out the paper which is blank. when i command a job, it just prints a blank page with out any writings
Do you hear the sound of the solenoid of the printer head during printing? if not then there is a cut traces on the head cable. if you hear it then you have to change the ribbon. try also to check the lever adjust bar on the printer (usually found with a blue head on the left part if it is an lq-2180++ model or on the right part if it is an Lx300++)
Feb 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
It printing but with black forms on paper
black form because of ribbon is touching to the paper for this solution is adjust head gap of the printer or put the leaver in 3+1 setting ...and try ....
replace the ribbon mask ..........
Dec 10, 2009 | Epson LQ-2090 Matrix Printer
I have an Epson LX-300 dot matrix. The problem is the print is smudged/with black lines patches along the printed matter. The ribbon mask is lost. I'm curious to know the purpose of this ribbon mask. Does...
The mask stops this sort of problem and the print head could do with cleaning so that the pins don’t get stuck. The ink coagulates over the years and causes the pins to jam and eventually tear up ribbons of just burn up the driver coils in the head assembly. The head face needs cleaning with a cotton bud or two or three with isopropyl alcohol to remove all the ink residue from the pins and shafts. If you can remove the head assembly this is much easier to do.
Oct 30, 2009 | Epson LX-300 Matrix Printer
When i give the print the printing head not moving
unplug for a few mins then restart make sure you dont touch the ribbon also make sure ink wells are snapped in properly
Apr 02, 2009 | Epson LQ-2180 Dot Matrix Printer
Printing problem on Epson LQ 2070
check on the Bios of the computer try to set the parallel mode to ECP enhanced compatibility port, because some dios are on epp mode
Jan 07, 2008 | Epson LQ 2070 Matrix Printer
Epson Dot Matrix LQ-300+ Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
