Question about Sony Playstation 3 (PS3) Console
Ps3 turns on but no menu icons show up
My ps3 turns on and shows the wavy background for the home menu screen but no menu icons show up. Nothing on the controller changes anything and icons never come up. The wavy colored background is there though
2 Suggested Answers
  • 1139 Answers
SOURCE: My ps3 turns on and shows the wavy background for
This problem is because your PS3 software has become corrupt. The following steps will cure the problem but you will lose saved games and all other data. Your trophies will not be affected as these are stored by the Playstation Network.
Step 1. Turn your PS3 onto standby (Red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, beep 5 seconds later then beep once more 5 seconds later and then turn back to standby. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and then beep twice quickly. Let go of the power button as soon as you hear these two beeps.
Step 4. The PS3 will start up asking you to plug in a controller with a USB cable and press the PS button. Do this and it will boot into the recovery menu.
Step 5. Choose option 5 (Restore PS3 system). This will re-install the PS3 software and restart the console.
Step 6. When the PS3 restarts you will be asked to enter the time and date and other information. When the setup is complete your PS3 will boot into the home menu normally.
Hope this helps
Posted on Aug 11, 2010
Testimonial: "seems as if everything is in order now. thank you verry much."
My PS3 has been broken for a very long period of time. About 6-9 months now, I've lost track. Every time I turn it on my PS3, it starts with the wavy animation and the colored background, and then the...
Ok, please try the following steps :
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep a total of 3 times and turn off again. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, then 5 seconds later it will beep again and then it will beep twice quickly. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this then continue to the next step
Step 5. The PS3 will load with a menu with 6 options, choose number 5 "Restore PS3 System" and follow the on screen prompts.
Using this method should sort your PS3 out for you.
Hope this helps
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 turns on and shows the wavy background for the home menu screen but no menu icons show up. Nothing on the controller changes anything and icons never come up. The wavy colored background is there...
Hope this helps
Aug 11, 2010 | Sony Playstation 3 (PS3) Console
My PS3 dos not allow my controllers to connect and also does not show anything but the background
did u try pressing the middle button on both of them if u did that then u need to charge the controllers
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
My ps3 isn't showing a menu, just the wavy line and star screen?
turn your ps3 off then when you touch the power butter hold it iuntil you hear two beeps on the second beep let go and the main system ovveride scree will show up click on restore settings to default and it should go back to normal
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
Turn on the ps3 and it shows the green light on but nothing appears on the screen instead of the background but no icons
sounds like u need to reset video which is hold down power button after u restart it for like 5 secs its something in power button that resets video.
Jan 24, 2010 | Sony Playstation 3 (PS3) Console
Home screen shows only backround. No icons
Switch the PS3 off (Red Light). Hold your finger on the power button until the PS3 switches on and off. Take your finger off and hold it in again. It will come on. Hold it until you hear a double beep and take it off immediately. You will then be taken into a recovery menu. It will ask you to connect your controller via USB. Choose option 3 - Restore File System (Do not try any other option as it will erase some or all data on your HDD). It should work after this.
Hope it helps you.
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
When i turn it on the screen is only white
To show a hidden icon on the Home screen, complete the following steps:
  1. Select an icon on the Home screen of the BlackBerry smartphone.
  2. Press the Menu key.
  3. Click Show All.
After the Show All option has been selected, to show a hidden icon, complete the following steps:
  1. Select the transparent icon on the Home screen that you want to make visible.
  3. Cancel the Hide Icon selection.
Oct 29, 2009 | RIM BlackBerry Pearl 8100
My ps3 doesn't show any of the Icons
Yea, i've called sony quite a few times myself and got no help.
You can use the 'new' feature they added. Turn on your PS3 and hold the power button till you hear two beeps, then release. Its a recovery menu you can use to try and fix it. If that doesnt work you may have to send it in for repairs, The menu only works on firmware 2.50 and up.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
Wont start up
we have the same problem but i got one step to make it enter the system,, when turning on ur ps3 u nid to hold the switch until u hear the 2nd sound,, once that happen the system will show up but there is still a problem in my ps3,, u can see the system but it will not load games or any video icons in the system,, u will only see settings configuration there but once u click it the ps3 will freeze,, comment me if u had the same problem in entering the system,, i doubt that i need to format the hdd via pc,,
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
629 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
