Question about Targus Noteworthy Multimedia Keyboard (NWKBMO)
Old keyboard still connected note worthy keyboard
Old keyboard still connected (keyboard port) Targus Noteworthy keyboard (model no: nwkbmo)(usb port) wont work.
num lock, caps lock, scroll lock lights stay on. keys are unresponsive. i got the keys to work once but the top buttons (play/pause, stop, fast forward, vol +/-, etc) didn't work.
    President:
  • 2,017 Answers
When you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
Posted on Sep 08, 2009
None of the keys are working
Try a regular usb keyboard to make sure it is functioning properly
If so may need to replace keyboard
Also try a different usb port
Jun 25, 2011 | Targus USB Ultra Mini Keypad Keyboard...
Not able to get an IP from the network when connecting thru the Targus docking station model ( APC51US) i am on windows 7. note that i am using the same cable adn it work fine when i connect it to the...
In order to use the ethernet card on your Docking Station ( or Port Replicator), you must first disable any internal Ethernet cards.
To do this:
  1. Type "Network Connections" in the Start Menu seach box, and press enter.
  2. Right click on your computer's internal ethernet adapter (i.e. "Local Area Connection" & select "Disable"
Ref: Targus Support
Apr 19, 2011 | Targus Port Replicator, Docking Station,...
My mouse targus AMU51US can not work because i do not have a driver , because when i bought it,in the pakage is not included the driver,
http://www.targus.com/us/content.aspx?page=downloads
o find the Manual or Driver for your product:
  • Use the Site search at the top-right corner of the site.
  • Visit the product page by selecting your model from the list.
    (NOTE: You may need to select the "Archive" tab).
  • If available, select "Drivers & Downloads" in the black box beneath the price.
  • Go to the "Driver" tab and select the appropriate driver for your device.
    NOTE: If no downloads are available for your model, the "Downloads" link will be hidden on the product page
Mar 13, 2011 | Targus AMU51US 3BTN USB OPTICAL ACCSLAPTOP...
USB ports do not work with my XP Dell computer
Did you connect the power to the Port Replicator? The USB may be older in the Targus or the XP Dell. (1.1 older, vs 2.0 newer).
Sep 16, 2010 | Targus Port Replicator, Docking Station,...
Targus Bluetooth Laser Mouse Rechargeable Battery Trouble
check batterys to make sure there placed in mouse properly.try other usb ports.Batterys may be bad from factory.try some other rechargeables in it.if you have a charger for rechargeable batterys place the batterys in that and see if they charge.if they do then your pc is not charging them correctly/
Jun 11, 2009 | Targus Bluetooth Laser Mouse...
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Feb 25, 2008 | Targus AMW15US
Targus wireless notebook mouse
See for Windows, the answer is yes. This is because when Windows detects that the mouse is not connected, it may freeze. Also may not boot up all the way from restart either. You can always get a multi port USB hub if you need more USB ports.
Nov 20, 2007 | Targus Wireless Optical Notebook Mouse...
Targus Noteworthy Multimedia Keyboard (NWKBMO) Logo
165 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
