My machine wouldn t start so I tried pusing a few buttons and I got an error E2 displayed Anyone kn problem:
    Brigadier General:
  • 3,513 Answers
Hi...
E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Apparently, the E2 code means a button is stuck on the touch panel. replacing the whole touch panel and control board will be helpfull.
thankyou for contacting Fixya.com
Posted on Sep 08, 2009
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
Jan 20, 2016 | Bosch Washing Machines
I have a bwm 50 washing machine displaying e2
Hope this helps
Bob
Jan 12, 2015 | Washing Machines
What does error code E2 mean? I have a Bosch Maxx Classic.
to fix you must do a master reset of the washing machine.
Nov 03, 2009 | Bosch Washing Machines
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Bosch Washing MAchine - E2 error message
Hi.
E2 means uneven balance.
The error code gets reset using the following procedure:
Ensure that the machine door is closed. Turn the dial in the OFF position.
Hold down Start/Pause button and turn the dial anti clockwise at the same time until its position is pointing at the Express (15mins) program.
Hold down Start/Pause button until the e2 message starts flashing (or keep holding for about one minute)
Release the button.
Turn the dial again to the OFF position.
The machine is reset. Select any program.
If the message comes back after selecting program, then there is still a balancing problem. Remove and redistribute load, check floor and ensure machine is at level.
Jan 31, 2009 | Bosch WFMC 3200 Front Load Washer
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 | Ovens
CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
I have only worked on USA machines but I believe you have a control panel error.
Sep 27, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
