Compaq peserio sr1000 is not booting ,powersupply,RAM
Compaq peserio sr1000 is not booting ,powersupply is ok ,
    Master:
    Sergeant:
  • 460 Answers
May be your desktop RAM or Motherboard is faulty. so pls checked it from computer store.
Posted on Sep 08, 2009
My compaq persario sr1000 power is on the fan is on. but it beeps with a short beep and keep on. beeps pause and beeps again all with the power on but no picture on the moniter
Your ram/ram slot may have gone bad, contact Compaq Tech support for detailed instructions.
For a basic idea of what to do if you know what your doing:
1. Pull out 1 ram card in the first slot
2. Start up system
3. If beeping appears leave that slot empty
4. continue until beeping stops
Side Note:
If you keep removing all the ram cards and the beeping continues, I probably got the wrong error.
Mar 01, 2011 | Computers & Internet
When i switch on my laptop and starting windows on logon screen my laptop keyboard & mouse does't work after 20 minutes it goes ok automatically i format hdd and reinstall windows but the problem is...
I would boot up to safemode (assuming that works) and type MSCONFIG in the run box. Check selective startup, then go to the selective start up tab and uncheck everything.
Click apply or ok.
Restart the PC and let windows load normally. If it does, then one of the things you unchecked was causing the problem.
I would then open the MSCONFIG again (can do this without entering SAFE mode for now). And then check one thing back at a time and restart the PC. If it hangs up on the last thing you unchecked than you have your answer.
Go back to safemode and uninstall whatever was causing the hangup.
If that does not work try these steps,
Maybe some hardware is at fault.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit.
Good luck.
Jul 08, 2009 | Acer Aspire AX1200-BE5600A 22' wide-screen...
WILL NOT BOOT UP IT STALLS OUT.
Click apply or ok.
For hardware issue try this:
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Jul 07, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
My computer keeps booting every 2 seconds and I just can see motherboards first screen during 1 second then cant see anything else
I am almost positive it is the ram, because it gets to windows but crashes after loading windows partially. I once had a similar problem. Just make sure all the Power Supply connectors are properly connected.
Try these steps too:
Jul 07, 2009 | Intel D865GBF Motherboard
Cooling fan does not come on no power to the computer
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
Jul 07, 2009 | HP (158800-001) for Compaq Presario 1246,...
Dell 4400 won't power up Flea light works
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Jun 28, 2009 | Dell Dimension 4400 Power Supply ** FREE...
How much ram mem can i put into a compaq sr1000
It depends on which sr1000 you have, there are 5 in that serie.
How many memoslots di you have?
If you have 2, then it is max 2GB memory
If you have 4 slots, then it is max 4GB memory
The SR1000IL model supports 4GB, all the others supports 2GB
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 16, 2008 | Compaq Presario SR1000T (568657) PC...
I have HP compaq peserio 6720s laptop.
Look around the Internet for a blank administrator password CD. You can find various ones to download (like UBCD) and then create a bootable CD. Once that is done, simply boot, using the CD, and follow the prompts to blank the administrator password. Log in using the admin account and create a good, strong (but memorable) password.
I hope this helps. If it does, please rate the solution.
Regards,
Char1ieJ
Nov 19, 2008 | Compaq Presario Notebook
Compaq Presario SR1000 desktop boot up problem
nothing to do with the ram ... this motherboard sometimes locks, ( dont ask me why) but if you take out the power cord for 5-10 minutes and then press and hold the front power button on the machine (about 10 seconds) it will reset the board. Plug in the power cord and the basic items, sound, video etc ( some usb devices tend to stop it booting to) boot into windows. Then add the rest of your usb devices ..
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
