Question about Mitsubishi LT-3780 37 in. LCD Television
Where can I buy media box(HD BOX) for my 2005 Mitsubishi LT3780D? I have lost it. Now my TV is just a monitor.
  • 979 Answers
SOURCE: Mitsubishi hd 1080
The format of what you are watching plays a major part in whether all of the screen is used. If the program is 4:3 the screen will remain pretty much square. 16: 9 would be the most desirable for filling all the area. Go ahead and acquire a manual, they're not much...accordianman
Posted on Feb 27, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
Posted on Mar 27, 2008
SOURCE: Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Posted on Jan 22, 2009
  • 58 Answers
SOURCE: big grey box keeps popping up on screen...especially with dvd in
Make sure the SAP (second audio portion ) is not activated
Posted on Apr 25, 2009
  • 64 Answers
SOURCE: I have a Mitsubishi WD-62525, and when the Directv
The Manual speaks clearly on pages 14 & 26 to this connection (the cable is not supplied however). You will need to use NetCommand to assign the HDMI input to the Device you are using and the select the Input to be used (via the TV remote) to that input. Note carefully the first few pages starting with Chapter 3 (NetCommand Setup & Editing)
Posted on Aug 03, 2009
Were is the Ariel output
You have bought a monitor NOT a tv. You need to buy/obtain a separate tuner box for tv signals then connect your tuner box to your monitor.
May 10, 2014 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
LT-3780 37 in. LCD Television screen flashing intermidindly all modes but pc mode
I have to respectfully disagree. These televisions are two-part systems. You have the LCD monitor and the HD-4001 Media Center. If the media center is defective, it will send a bad video signal to the monitor. If you are getting perfect PC video, then the LCD panel is fine. You can connect your cable box or DVD player directly through the HDMI port on the back of the monitor. You will only be able to have one plugged in at a time. The HD-4001's are hard to come by now, but you may be able to have it repaired.
Oct 05, 2011 | Mitsubishi LT-3780 37 in. LCD Television
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
If we have an hd-ready television and we have dishnetwork hd does their box make our tv hd? Or do we have to have their magical piece of equipment to make our television hd?or tv is the WS-55315 model.
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
SD TECH
Jul 11, 2010 | Mitsubishi WS-55315 55" Rear Projection...
How can I hook up 2005 Mitsubishi LT-3780D with cable TV? Because in the back of TV looks more like computer's monitor, I can not connect it with a cable cord.,
Your LT-3780 LCD is only one part of a two-part television system. The LCD is the "monitor" and the HD-4001 "Media Center" is where the inputs and outputs are for the television. The HD-4001 was included with the LT-3780. They are connected together with an HDMI cable and a Serial Cable for communications. If you don't have the HD-4001, you can connect your cable box or DVD player directly to the LT-3780 with an HDMI cable. You will not have any means to connect more than one device at a time, as this feature was performed by the media center. You will also be unable to connect any S-Video, Composite, or Component devices, as these connections are only on the back of the Media Center.
Aug 13, 2009 | Mitsubishi LT-3780 37 in. LCD Television
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Please help
Could also be the cable, set are now designed if no signal to shutdown, so first check media box by calling cable company and or replace and try another just to make sure.
Aug 27, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Mitsubishi LT-3780 37 in. LCD Television Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
