Question about ASUS Geforce 6600 GT Extreme 128MB DDR3/PCI-E/TV-Out/DVI Retail Box Graphic Card
Hi! I'm using a 6600gt with tv-out on a panasoninc crt tv and i can't seem to make the image color. All i see is black and white, despite trying all that i know to modify the settings.
  • 490 Answers
Find the setting that lets choose between 50hz and 60hz on the tv and change it to the other one not sure if this your problem but i have had this problem and changing that setting seems to change the colour
Posted on Sep 08, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Philips 60PP9200D went black and white.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixelation ,black and white picture,even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 05, 2010 | Philips 60PP9200D Television
My sony 29'' color tv turned black and white.color sometimes flash on the screen.video and sound is normal.pls help
     If your TV colors get black and white with flickering then there must be a problem of cold soldering(Loosing) and it can be remove from resold, Resold in video section and problem will be solved.
     Thanks.
Jan 14, 2010 | Sony Televison & Video
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
dear,
there must be some options either in tv mod or in dvd, is not properly selected..
check both manual in details...
regards,
dont forget to rate
Aug 10, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Metz CRT TV G3478 color problem in PAL mode
I see from your profile that you have not specified your location which make it tricky to be sure which standard you should be using.
Oct 07, 2007 | Televison & Video
Black and white images
I had the same problem with my Playstion2. I found that the playstion was givin an NTSC video output but the TV was only for PAL. try it on a TV that is PAL if your gamestation is PAL or on an NTSC tv if its NTSC. Does this help?
May 26, 2007 | Microsoft Xbox Console
ASUS Geforce 6600 GT Extreme 128MB DDR3/PCI-E/TV-Out/DVI Retail Box Graphic Card Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
