Question about Sewing Machines
Old singer sewing machine (306k) motor works,belt o.k. but drive to needle is very stiff needle barely moves / peter
  • Sewing Machines Master
  • 1,388 Answers
Apply a little singer machine oil to each of the holes along the top and in the working area next to needleplate.........rock handwheel gently and make several full rotations in each direction ......... keep at the rocking and rolling periodically over several hours if necessary....it should come good after a little patience and persistence. Do not apply too much oil, it will only make a mess. NOTE: Belt needs a little give to prevent motor overload, so do not overtighten.
Posted on Sep 10, 2009
I was given an old Singer Stylist 513 sewing machine. The light works, but the machine will hum--that's all. The needle will not move. I have never used a sewing machine in my life, so I'm lost. Any...
In case you do not have the manual the link is a free downloadable manual from Singer. Make sure everything is plugged in correctly. Check the connection from the machine to the foot controller. Instruction Manuals
Andy Tube has videos of the 513 you may find helpful. http://www.youtube.com/playlist?list=PLsCOZgzzaiKJKoWgl8z-QIZCK70z3yhdH
Aug 11, 2017 | Singer Sewing Machines
I have a singer 301a machine from a cabinet. The needle mechanism does not work at all, but the motor turns. Am I missing something? George
Could be seized due to old oil that has dried. Could also have a belt that is slipping or broken. Does the needle move if you hand rotate the handwheel?
Wheel on right side that controls the needle up and down is very tight...
Information about your machine:
Singer 301 About the Singer 301
Jul 31, 2017 | Singer Sewing Machines
Singer 306K original Manual states needle is 206 x 13 dont seem to be able to find any, what can i use that doesnt drop stitches?
Help with Singer 306K - Sewing Discussion at Stitcher's Guild ...
artisanssquare.com > ... > Sewing Machines
Nov 22, 2013 - 33 posts - ‎8 authors
Unless,the original bobbin case has been modified,or someone bought a newer ... In Ed's blog here are pictures of a 206x13 needle vs a regular 15x1 needle and ... Here is a free Singer 306K automatic sewing machine pdf manual,with ..... I was upset and so I didn't get any more details over the phone. Author Topic: Is there such a machine as
Jul 6, 2012
Singer 319 find
May 13, 2009
More results from artisanssquare.com
Missing: states
Singer 320K2, Singer 306K Bobbin Case Conversion for ...
andrewcaddle.com/.../singer-320k2-singer-306k-bobbin-case-conversion...
Sep 13, 2014 - I recently had the good fortune to pick up a Singer 320K2 sewing machine. ... as well as Singer's zig zag model 206 utilise a needle design (206X13) which ... The 206×13 needles are becoming rare, with only two sizes and only one ....Neither can I state, beyond any doubt, that this modification won't cause ...
Jan 11, 2016 | Singer Sewing Machines
Bobbins for singer 306k sewing machine
You can find your bobbin--as well as your bobbin case and other accessories and parts--at Sewing Parts Online. Just select Singer parts on the left hand side, and enter your model number in the search box, and it will take you right there. They also sell the foot pedal, needle plate, and a lot of other parts for your machine as well.
Feb 21, 2015 | Singer Sewing Machines
Where can i find needles for a singer 306k machine ?
What type of material are you going to be sewing? Sew-Classic has 10 needle packages of the size 12 and size 14 needles for the Singer 306 for light (not fine) and medium weight material. (It's a 206x13 needle for the single needle. The twin needle is a 306x3.) See http://shop.sew-classic.com/206x13-Sewing-Machine-Needles_c46.htm .
http://www.allbrands.com/products/15221-schmetz-german-206x13-flat-shank-needles-100-size has some notes on alternative needles. The site has boxes of 100 size 14 and size 12 needles. (The size 14 needles are out of stock due to delays on the manufacturer's side.) https://www.college-sewing.co.uk/206X13-SIZE-90-PACK-OF-10-NEEDLES (size 14) needles in stock.
Unfortunately, I do not see any twin needles available for the 306K. I hope this helps.
Feb 20, 2015 | Singer Sewing Machines
Why does my new Singer cg-500 stop working, then start for a little bit and stop again?
Probably thread wrapped around something....takeup crank, motor pully...if you can get inside to have a look great, if not, find someone who can.
Oct 25, 2011 | Singer CG500 Mechanical Sewing Machine
I bought a Singer 328K at a second hand shop. I cleaned and oiled it but the motor just hums and runs very slowly. I think the belt may need tightened or replaced. Is it possible to do it myself and...
The Singer 328K "style-o-matic" is a Class 66 sewing machine with a solid handwheel. Like the 328, and most style 66 machines, this one takes Singer Motor Belt # 193077. Any singer vendor should be able to help you and as of this writing (2010) the part runs around $10. In case you have a parts machine around or find vendors less knowledgeable here are some other machines using the same belt: Pfaff 330 Series Singer 127 Singer 128 Singer 15-88 Singer 15-90 Singer 15-91 Singer 185 Singer 185K3 Singer 206 Singer 206K Singer 223 Singer 27 Vibrating Shuttle Singer 306K Singer 306W Singer 319K Singer 327K Singer 327K Singer 328K Style-O-Matic (YOURS) Singer 329K Singer 66 Singer 66-1 Singer 66-14 Singer 66-16 Singer 66-18 Singer 66-24 Singer 66-4 Singer 66-6 Singer 66-8 Singer 99 Class Singer 99-13 Singer 99-31 Singer 99K
Hope this helps!
Aug 14, 2010 | Singer Sewing Machines
Singer electric, working fine last time I used it
Make sure the plug is plugged in all the way both to the machine as well as to the wall.
Jan 01, 2010 | Singer Sewing Machines
Singer sewing maching 306k.parts
ebay is best for 306k parts.
Dec 17, 2009 | Singer Sewing Machines
Sewing Machines Logo
274 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
