Question about Kinderkraft Vermont Crib
Side rail falls off
I have the Kinderkraft crib as well and the side rails fall off completely when I lower it. Tonight it fell on my foot!!! OUCH!!!
  • 340 Answers
Sounds like you may either be missing a piece of the moving side hardware, or have an item installed backwards (the moving side components are left and right orientation). We can email a copy of the assembly instructions to you as well as replace any missing or broken hardware that you may need. Please email your request to us at parts@productsamerica.com, and mention that is for a Kinderkraft Vermont (should be model 710 - check your label for model info), or call us at 800.205.9642 or 800.772.1041 for direct assistance.
Posted on Sep 18, 2009
I bought a kinderkraft crib used and it came with the hardware, but no instruction manual. Can I find assembly instrutions online?
  • I can tell you how to assemble it.
  1. Place an insert nut into the top of the stationary rail.
  2. Place another nut into the bottom of that same rail.
  3. Flip that rail over and put another nut into the top and bottom of it the same as you just did.
  4. Now stick a two bolts into one side of the headboard.
  5. Stand up the headboard and twist them bolds from the headboard into the stationary rail.
  6. Now you want to twist two bolts through the secondary headboard and through the other side of the stationary rail. Make sure not to tighten them bolts up to much yet.
  7. Now put the mattress support inside the crib.
  8. Take four bolts into the top holes that are pre-drilled in the slat on the headboard and then on through to the mattress support.
  9. Do the same now with the other slat support for the headboard.
  10. Now do the same with the two remaining slats for the secondary headboard.
  11. Now tighten all the bolts real well.
  12. Put the crib on it's side.
  13. Now your gonna stick the canisters into the legs. Tap them in with a hammer if they are a bit stubborn.
  14. Now slide the rubber off of the lower side bracket.
  15. Hold the front drop rail so that the push plate faces away from the crib.
  16. Now slide that front drop rail on the tracks until it is all the way in the crib and then reinstall the rubber stoppers.
  17. Now put the crib on it's casters and go over the crib and give it a once over and make sure everything is secure and tight.
  18. Crib is ready to use now.
Regards, Tony
May 02, 2011 | Toys
I need the brackets that go on the side rails that hold up the side rails - until you kick the bar on the crib that allows the siderails to fall...
Products America has the parts you need. Just give them a call at 800-205-9642 or 800-772-1041 Monday thru Friday from 8am to 6pm CST. They will ask you a few questions about your crib and possibly need some measurements so try to be with the crib if you can.
Nov 04, 2009 | Simmons Mattress Matino - Natural Maple...
Want to convert my son's delta crib into a toddler bed
If your crib didn't come with the side rails you may not be able to find them. also check for recalls the Delta cribs have been having a few.
Jul 25, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Missing Rubber Stoppers on Kinderkraft Crib Dreamer No. 305
You can probable just put a nail or srew in for now!
Here is the 800 number for kinderkraft. They have a website but it doesn't appear to be working. 1-800-822-6748
e-mail service@kinderkraft.com
http://kinderkraft.com/main.htm
Jan 13, 2009 | Kinderkraft Vermont Crib
Kinderkraft crib
Nov 23, 2008 | Kinderkraft Vermont Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Kinderkraft crib
You just take the drop down side off and put the mattress at the lowest setting. We have the same crib and used it for a few months as a toddler bed.
Jan 11, 2008 | Kinderkraft Vermont Crib
Converting crib into toddler bed
Typically you can loosen the bolts on the side of a crib slowly until you get to a point where the front rail will pop out of its track. After it is removed tighten up the bolts again! I am not sure what crib you have or if that will work the same way with your configuration. You should make sure you have the springs at the lowest position as well. You will then have a 3 sided toddler day bed. I hope this helps. Richard - www.goores.com & www.gooresblog.blogspot.com
Jul 14, 2007 | Kinderkraft Vermont Crib
Bassett crib sides falling down
You likely are missing the lower track assemblies. Part # CC (right) and DD (left). These screw into the lower inside legs on the side with the drop down rail to secure the rail from dropping off. See instructions, Step 1 and Step 2.
Call Bassett 1-276-629-6000 to obtain instructions and a parts list for model # 5926-0504 (look on the inside headboard - not the gold label).
Parts can be ordered from Products America 1-800-772-1041
May 29, 2007 | Bassett Parson Ridge Crib
Kinderkraft Vermont Crib Logo
273 people viewed this question
Top Kinderkraft Baby Gear Experts
Ted Maxwell
wcdoc1953
wcdoc1953
Tom Chichester
Are you a Kinderkraft Baby Gear Expert? Answer questions, earn points and help others
