-   cd loading system accepts the cd, but wont read it and ejects cd -   Guest
Nov 29, 2008
-   cd will not work error comes up and does not play the rest of the system works-   Guest
Sep 16, 2008
-   Window of unit flashes "ERROR" when I attempt to use the CD changer. The tray is stuck. The unit window shows 5 disks loaded; no disks are loaded. -   smokinjj
Jun 29, 2008
-   My wife bought a JVC MX-D661T a few years ago. The CD players stopped functioning properly some time ago. It tries to start but then will open it automatically. How can I fix it?-   frankxu88
Jun 26, 2008
-   cvd player not working and doesnt open. error shows-   Guest
My stereo worked unreliable. Sometimes it worked, but most times it said "no disc", spinned up like crazy and gave back the disc after a minute...
First of all: I solved it by replacing the laser unit.
In my case, I ordered a kss-213c-type laser-unit mounted completely with cd- and linear-motor via ebay. The next step was swapping it into the defective Hifi-set. That was bit of a work, but went okay due to the service-friendly conception of the set.
It turned out, that only the linear motor-section worked with the new mechanical/laser-unit. The disc didn`t spin up at all. Okay. No i had the pleasure to swap each component, step by step:
First, I replaced the spindle motor. Again, nothing happened. Onla the laser slid back and fourth and kept still than.
Secondly, I replaced the Laser unit. Be very careful with that point. It is very sensitive! In my case, the old unit worked suxessfully now. Along with new plastic-gears and two new motors alongside with the old drive-mothervoard, it works fine and 100%-reliable. I assume, that it were only the two plastic-gears, which were working no more calculable.
The Philips MCM530 goes on at random times, starts playing the demo at random times, changes...
(More)
The Philips MCM530 goes on at random times, starts playing the demo at random times, changes stations on its own, won't play a CD (plays 20 seconds then jumps to next track). I unplugged it and plugged it back in. Same problem. Is it a goner?
i have checked the speakers etc. and it still does it without speakers attached. I have tried...
(More)
i have checked the speakers etc. and it still does it without speakers attached. I have tried different power sources etc
I bought this system for my Mum and everything worked perfectly. However, since giving it to my Mum the CD player won't work. When the disc is put into the player, the display doesn't show any information. HELP!
Comment by Guest, posted on May 10, 2008
Installed CD and ush play. the player recognizes CD but will not play. Goes from 1 to 15 and elasped time but it will not play any of the CD.
i select the cd mode, but when i push the open button, then it displays Error Code 0306, and it wont open or play anything. everything else works fine.
