Question about Palm Treo 500 Centro
My palm centros down button will not push down. As well as that the center button is sticky. Is there any way to fix this?
  • 34 Answers
Hi! clean the contact of the key that is not functioning,because the problem is the stock up key or dirty key pad contact
Posted on Sep 08, 2009
Palm Centro Freezes on Power Up
try clearing up your web history, sms, or unwanted software....on the browser, click on blazer top left corner, click on history and clear all..tested if it doesnt work back up your phone and perform a master reset
Mar 23, 2010 | Palm Treo 500 Centro
My palm centro keyboard and other buttons randomly stopped workig
Hello hyuuga4567,
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option +
Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Sprint Palm Centro Smartphone
I did not know how to turn off my email connection of my palm centro cellphone
Hello p_belgado,
The email connection can not be turned off but the email application can deleted off the Palm centro if you don't want to use it. It can be deleted by doing the following:
•Press the home button
•Press the menu key (lower right-hand corner)
•Select 'Delete' in the drop-down menu
•Scroll through the list until the mail application is highlighted:
(The mail application probably starts with the letters 'MM...' [MultiMail]. And it could be 'VersaMail')
•Tap the 'Delete' button at the bottom of the screen
This procedure will delete the mail application and it will be archived on you computer during the next hotsync. If you get stuck doing this procedure, here's a link to the Palm Centro User Guide which can be quite helpfu:
http://www.palm.com/us/support/handbooks/centro/centrorow_ug.pdf
Have a great day,
martyshaw152
Feb 02, 2010 | AT&T Palm Centro Cell Phone - White
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
• Select Prefs
• Select Keyguard.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
Tried to lock my palm centro never gota question to set password just lock the device now cant get in my phone.
You may want to try a hard reset. Keep in mind you will lose all data in your phone. These steps restore the phone to factory settings
1. Remove the battery from the rear of the unit.
2. Hold down the power button while reinserting the battery.
3. When the Palm2_bing.gif logo appears, release the power button.
4. Press the Up button to complete the hard reset and erase all data on the Centro.
Dec 14, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
How do you do a master reset on palm centro cell phone?
Hard reset - remove battery, reinstall battery and hold down power button continuously as the "palm" screen loads and the black bar moves across the screen, release. The phone will then select a language and prompt for a reformat.
Aug 03, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Hi, my palm centro has no sound. i.e, no speakerphone, no dial tone, no audio on videos but the alarm works that's it.
Hello rossgreni340,
First, make sure the ringer switch is set to 'ON'. It's the little button on top of the Centro. It's turned on when it's pushed to the left. If that doesn't help then check the Sounds settings. The Palm Centro sounds settings can be accessed and changed from the 'System' screen like this:
•Press the 'Home' button on the Centro.
•Tap the 'System' category (top of sscreen).
•Tap 'Sounds' to change the sound settings as you desire.
I hope this helps to resolve the sound problem.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw152
Jul 29, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My Centro started hot syncing itself.
try this: take the battery out, then hold down the red power button...keep holding it until you put the battery back in and your screen comes on. Hope this helps, it worked for my daughter's!
Jul 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Its locked up
Is your Palm Centro device locked up and frozen. You might want to try a hard reset. Here’s how.
3. When the second Palm logo appears, release the power button.
Mar 31, 2009 | Palm Treo 500 Centro
Hard reset for palm centro
When performing a hard reset on the Palm Centro, you hold down the power button as you insert the battery, and then release the power button when you see the second Palm logo.
http://www.palm.com/us/support/downloads/centroupdate/pop_centrohardreset.html
Jun 29, 2008 | Palm Treo 500 Centro
Palm Treo 500 Centro Logo
189 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
