Question about Bosch Integra® 500 SHX55M05UC Built-in Dishwasher
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
  • 512 Answers
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Posted on Sep 08, 2009
My maytag dishwasher MDB8750AWS has an odor while washing an after completed cycle
Hello Thomas;
My name is Peter. I am a retired field service appliance technician.
Your dish washer just need a good cleaning. Plastic is holds odors.
Pour 1/2 cup of white distilled vinegar in the bottom of the dishwasher. Run on hot and heavy load. Spread 1/2 cup of baking soda in the bottom of the dishwasher and let set over night. Run the dishwasher in the morning.
Dec 09, 2014 | Maytag Dishwashers
Dishes have bad odor after being washed. Changed dishes and detergent. What's wrong?
Bonjour mon ami,
Your dishwasher has a build up of bacteria that would be causing the smell. I would sugsuggest purchasing a rinse-aid from your local supermarket. This is a pack you place in your dishwasher and run on a full cycle without any dishes.
It should disinfect your device and clear up the issue for you.
Also at the bottom on the inside there will be a small drain be sure to empty this regularly.
kind regards,
Geoff
Nov 13, 2014 | Dishwashers
Bosch shx43c at end of cycle doesn't completely drain. leavs some dirty residue on dishes (water temp set at 120) cleaned filters water standing in lower filter basin (creates odor) and took hose...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 25, 2011 | Bosch Integra 300 Series SHX43C0xUC...
Dishwasher is not drying. At end of cycle, dishes are still wet and damp, as well as the inside. Buttons are all pushed. Also, it seems to wash for more than one cycle. Did a light wash and after 1-1/2...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
There is a smell in the dishwasher and on the dishes when clean
I suspect stagnant water is laying in the bottom areas. You will have to lay the machine on it's back to access the pump.
May 27, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Foul odor on dishes and in dishwasher after cycle
It is very likely that your dishwasher is growing mold, in this condition. If it is causing your dishes the same issue, it may be wisest to obtain a dishwasher cleanser(Several detergent manufacturers now sell dishwasher cleaning items), which will hopefully kill off any mold colonies growing in your dishwasher's blades, and in your drain cap.
Apr 23, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
It seems to take a long time to run the dishwasher, and when complete dishes are still damp, and there is an odor in the dishwasher.
check all filters,it sounds like you have blocked filters .take two tablets and put them in the machine and run the machine at its hottest tempture and see if this solves your problem.yours adrian;;;;;;;;;
Jan 22, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwater odor
Lots of ideas,,, Try cycling the dishwasher without dishes on the hottest setting and about 10 miutes into that cycle..stop it and add 2 ups of white vinegar to the water.. let it complete the cycle..
The problem is that standing water with food byproducts will begin to smell as they break down. Like all dishwahers, there is always a small amount of water that remains in the drain system at all times so it is important to clean the filter trap and to periodically air it out or use the white vinegar method..
Hope this helps you...
Sep 23, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Food odor builds up if dishes not washed daily, even though we rinse evrything thoroughly before loading dishwasher. No water remains at bottom - nothing appears to be stuck in drain. Any thoughts?
No matter how well you rinse wares, some food particles will always go into the machine. Sometimes these particles can build up and lead to what you describe. I would start by inpecting the wash tub area; remove screens, remove wash arms and clean as needed. You are looking for any residual food soil which would harbor bacteria. If all else fails, follow your nose!
Once everything is as clean as you can make it, then purchase a product for cleaning/deliming your machine. One I know of is called "Dishwasher Magic" which should be available at most appliance repair stores. Run this through the machine on a long or heavy cycle. Once complete, run a second cycle with nothing but water to rinse any lingering chemistry.
Lastly, for a 3rd (and final) cycle, add a cup of bleach to kill off any remaining odor-causing bacteria. But, DO NOT SKIP THE RINSE CYCLE mentioned above.
This should take care of the problem,
Kermit
Aug 23, 2008 | LG LDF6810 Built-in Dishwasher
Cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Sep 17, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Bosch Integra® 500 SHX55M05UC Built-in Dishwasher Logo
403 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
