Question about Nordic Track NordicTrack Treadmill, A2550
My nordic track A2250 will not start when key is placed on everything lights up it beeps three times and then any button i push it just beeps the belt will not start? Any suggestion I have misplaced my owners manual
5 Suggested Answers
  • 18 Answers
SOURCE: How do you replace the walking platform on the
First, remove the motor hood. There are 3 screws at the front, and 2 underneath. The screws underneath will have to be removed by tipping the treadmill over, or pulling the console towards the rear of the machine.
Next, remove the side rails. This is a little tricky because of the cushion adjusters on each side of the deck. If you look underneath the deck, you will see that the adjusters are on rails that are attached to the platform. Remove all of the screws from the side rail and push it toward the rear of the machine while also moving the adjusters rearward. You'll have to kind of move them together until the adjuster slides off the rail. Do both sides.
Remove the rear roller, by loosening the bolts. Don't mess with the front roller unless you intend to replace the motor belt. You don't need to remove the front roller or the walking belt.
There are 4 bolts holding the deck to the frame. The rear ones go through the frame to a lock nut. The front bolts screw into the isolators. Remove them and the deck will come loose. You can slide it out from the walking belt.
Place the new deck next to the old, and start moving the parts over. Make sure the safety decal is on the bottom like the old deck. All of the holes are pre-drilled except for the belt guides. You'll have to measure for these. Now do everything in reverse to reassemble the machine. I'm also attaching instructions on how to adjust the belt.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
Good Luck!
Posted on Mar 11, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
  • 3 Answers
SOURCE: C2155 treadmill 1 1/2 yrs old, Nordic track. Panel
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Posted on Oct 29, 2011
Have a nordictract a2250 the lights come on on the dash but nothing turn on just light up after you touch any button it's beep 3 x
I have a 2500 and had a similar problem, console lit up but no functions. I followed the suggestions on other boards and unplugged the iFit cable from the main board. Works just fine now. To do so, you have to remove 10-12 screw from the underside and then trace the ribbon cable back to the board and wiggle it out.
Oct 30, 2013 | Nordic Track NordicTrack Treadmill, A2550
When I plug my Nordictrack A2250 in the fan runs and the screen is blue, none of the buttons work. This is without the safety pin attached.
Adjust the REED switch, test it, clean it, and tight the plug or connector very well.
2) replace batteries with the same type, same mark, same polarity
3)clean contacts spring with c. cleaner spray. buy it from some electronic store.
God bless you
Nov 29, 2012 | Nordic Track Nodictrack A2250 Console...
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
Jun 17, 2012 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
C2155 treadmill 1 1/2 yrs old, Nordic track. Panel lights up when the key is attached, beeps a triple beep sound fast about every 15 seconds? Keeps beeping when any of the buttons are pushed and won't...
Jun 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Dec 15, 2009 | Nordic Track Exercise & Fitness
I have a NordicTrack A2250, about 2 years old. When it's turned on, the control panel lights up, and when I insert a program chip, the console "speaks". However, the neither the incline nor the belt...
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
Dec 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
705 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
