Question about Philips 50P8341 50" Rear Projection Television
TRANSPORTING A REAR PROJECTION tv
I WANT TO TRANSPORT ABOUT 100 MILES A REAR PROJECTION pHILIPS tv. i KNOW IT WEIGHS 189 LBS AND i PLAN TO USE A UTILITY TRAILER TO TRANSPORT MODEL 50P8341A. YOUR HELP IS NEEDED TO INSURE OR ATTEMPT TO MOVE THIS UNIT SAFELY. mANUALS OR USER GUIDES HVE BEEN LOST. uNABLE TO FIND THE REPLACEMENT USERS GUIDE OR MANUALS AND NEED TO KNOW THE PARTICULAR CAUTIONS TO OFF SET OR PREVENT WREAKING A TV THAT IS WORKING PERFECTLY NOW.
    Problem Solver:
  • 9 Answers
One major suggestion i will make it do not let it fall over or even tip to the side. With most projection tvs any damage to alignment or anything like that can be undone with a correction to the bulb alignment. Any tv repair place should be able to walk you through this or do it for you for a relatively reasonable fee.
Posted on Sep 08, 2009
Moving the TV
TV should be in upright position during transportation in some safe packing around it.
Thanks.
May 13, 2010 | Toshiba 50H82 50" Rear Projection...
The set was transported. The back had to be
tv is too old to find much on it however, you can try this , with your remote control press menu, 1,3,7,0 then use the adjust key to access e2 then press qv. hope this helps
Sep 17, 2009 | Mitsubishi VS-50703 50" Rear Projection...
Precautions for moving a projection TV
shaking banging and rocking arent good for them eithor
Jul 29, 2009 | Televison & Video
Have a mitsubishi 65" wide screen, hdtv
The Light Box can be removed but that will not help you. I do not know of any way to shorten the TV.
Jul 26, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Can you lay a hitachi projection tv down to transport it
rear projection tvs can laydown ON ITS BACK. if its in an open bed truck and plan on standing up. DO NOT FACE SCREEN TWORDS HOOD!!!!!! the screen will cave in. hope that helps.
Jun 04, 2009 | Televison & Video
Philips Rear projectoion tv picture not clear
no its not true, you can lay them flat to move, it sounds like the convergence is out of whack, download the owners manual and redo the convergence manually for the red and blue, then go back and do the same for the multi point convergence for the red and blue, also if the color looks muted or flat, the projector lenses might need to be cleaned as well as the mirror in side of the unit.... very easy to do, just use caution and DO NOT SPRAY ANY LIQUIDS INSIDE THE UNIT.... spray the cleaning rag outside the unit the wipe off the mirror and lenses....i got this same TV free from craigs list here in pa, put a new mirror in because the original was shattered and re did the convergence and this TV pic is AWSOME.... very crisp and clear...hope this helps you
Feb 23, 2009 | Philips 43PP9202 43" Rear Projection...
Finding mirror glass replacement in projection tv
THe part n umber will be dependent upon the exact model number of your set. Can you please post that model number. This entry is listed under model number PT-47WX49. Pleaes confirm the model so we can get the proper part number.
Thanks,
Dan
Feb 09, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51G44 51 transporting?
No you should only transport it standing up to ensure the optics do not get messed up. I have seen peeps do this and nothing happens. I have also seen pros do the move on the back or the sides and it tears up the TV set. Good Luck
Aug 30, 2007 | Panasonic PT-51G44 51" Rear Projection...
I need to replace the mirror, it broke during transport
Take the back bezel off. It should have many screws around it. then once open you should see the back of the mirror. Carefully take the screws out of the mirror, you may have to do some modifing with the new mirror if it does not come prefabed.
Aug 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
275 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
