Question about Haier HTE18WAA Top Freezer Refrigerator
My freezer teperature is fine, well below zero as I have the temperature control to maximum, but the fridge temp is at about 55-60 degrees. I started by cleaning the coils, which were filthy, but no difference after a couple of days. The refrigerator seal seems to be in fine shape with no leaks (about 4 years old), and even when taping the door tightly shut overnight there is no difference. The compressor seems to be running continuously. I am not well-versed in refrigerator operation, but there may be a fan behind the vent holes in the back of the freezer, perhaps designed to flow air into the fridge, that may have quit. I am not positive. Even if that is true, the parts list names two fan motors, and I do not know which is which (the one at the bottom of the fridge next to the compressor is still operating fine. There are also two holes in the top of the fridge compartment that I assume should have air flowing through them but there is not. Though I can feel some ice inside the holes when checking it out, I would not say they are completely clogged. Any help would be greatly appreciated. Thank you.
  • 512 Answers
You have already dianosed the problem. Now take that cover off in the freezer and see if you can get that fan to work, it is your problem and you can replace it IF it is bad or lube it's bushings and see if it will work a few more years. (use 3 in 1 oil) Gook luck!
Posted on Sep 08, 2009
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Freezer will not work due to out side teperature being low
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Jan 06, 2009 | Hoover HCA351K Bottom Freezer Refrigerator
Freezer okay, fridge warm
i suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Refrigerators
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Our amana fridge model # BH2055W, with a botom freezer will not maintain the temperature.A repairman put in more fluid, but that did not solve the problem. It will not get cold enough and does not...
CHECK THE FREEZER TEMP FOR ZERO DEGREES. PUT A THERMOMETER IN THE FREEZER THAT WILL MEASURE DOWN TO ZERO DEGREES. LET IT SET OVER NIGHT BEFORE CHECKING. IF THE TEMP IN THE FREEZER IS ZERO OR LOWER, THE SEALED SYSTEM IS O.K. IT IS AN AIR FLOW PROBLEM. ON SOME MODELS, THE AIR TO THE FRESH FOOD COMPARTMENT IS CONTROLLED BY AN ELECTRIC, MOTORIZED AIR DAMPER. IT COULD BE DEFECTIVE, STAYING CLOSED WHEN THE CONTROL CALLS FOR MORE COLD AIR. IF YOUR REFRIGERATOR HAS A DIGITAL CONTROL, THERE IS A SENSOR IN EACH COMPARTMENT TO TELL THE ELECTRONIC CONTROL WHAT THE TEMP IS. THE SENSOR (THERMISTOR) COULD BE BREAKING DOWN, GIVING A FALSE READING. THIS WOULD ACCOUNT FOR THE TEMP VARIATIONS.
IF THE FREEZER IS ALSO WARM, THERE COULD BE A RESTRICTION IN THE SEALED SYSTEM. THERE COULD ALSO BE A PROBLEM WITH THE RELAY ON THE COMPRESSOR, NOT ALLOWING THE COMPRESSOR TO START UP WHEN IT IS NEEDED.
BE SURE THE CONDENSER FAN MOTOR IS RUNNING WITH THE COMPRESSOR AND THE CONDENSER COILS ARE NOT PLUGGED WITH DUST, DIRT OR FOREIGN OBJECTS.
Apr 08, 2008 | Refrigerators
May need defrosting, so do that, and also unplug the unit for 9 minutes, as this should reset anything that might have affected the problem. Check with Kenmore customer service department on how long the unit takes to get to a set temperature after resetting and consult your manual on your warranty options.
Mar 01, 2008 | Refrigerators
any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
Jan 30, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Haier HTE18WAA Top Freezer Refrigerator Logo
342 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
