Question about Whirlpool Dishwashers
Little pressure in washer - Whirlpool Dishwashers
  • marcusmartin Sep 08, 2009
    Yes, little pressure when the washer is running. My use&care guide, trouble shooting section, suggests checking the pump and spray arms for clogs. You also suggest checking the pump as well the screen. How is this done?
  • 512 Answers
Do you mean that when it is running, the water doesn't splash around and wash the dishes?
You need to inspect the pump and the screen into it. Could be blocked by trash but suspect the impellor is worn out or busted.
Posted on Sep 08, 2009
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Dec 05, 2012 | Coleman Powermate DuraBuilt 1400 PSI...
Tip
Pressure washer
I have repaired hundreds of pressure washer pumps.( Winterizing)Always tip up pressure washer to get out most of the water.Then purchase pump armor.This is like anti-freeze.If not available use light weight oil.(mineral oil is o.k.Tip back washer and pour a little in.Then pull motor start cord a couple of times and your safe for the winter.
on Oct 17, 2010 | Garden
Pressure washer has lost pressure
Although this costs a little money, it covers most home gas/electric and industrial portable kerosine/diesel fired hot water pressure washers. Worth sharing...
Aug 16, 2011 | Briggs & Stratton Garden
When using the sweep nozzle (yellow tip), the pressure starts and stops but the machine works fine when using the circluar nozzle(red)
usually when the power washer pressure stops the machine is running out of water. the sweep function uses a little more water than the round wash tip. Make sure there are no leaks in the supply hose and that the supply faucet is turned on all the way and has plenty of "flow". also make sure the water connection at the washer is not leaking. use a new rubber washer to make a good seal on the supply hose on both ends. if either end leaks or can **** air, just a little bit of air into the pressure washer will cause it to loose pressure.
Apr 20, 2011 | Briggs & Stratton Briggs Stratton 1800...
1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
May 06, 2010 | Karcher 1750 psi Electric Pressure Washer
Powerstroke pressure quit after 15 min. won't restart
Have a powerstroke gc 190 honda pressure washer the pressure is great for a little while then it seems to bleed off its a brand new machine. Not even 15 minutes on it.
Sep 05, 2009 | Karcher 2500 PSI Pressure Washer
I have very little pressure, not much more than a garden hose
check pressure head, I am assuming your talking about a pressure washer... also a worn pressure tip will cause loss of pressure
Aug 04, 2009 | Briggs & Stratton Garden
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
