Question about Canon PIXMA MP780 All-In-One InkJet Printer
How do I install my paper into my printer? - Canon PIXMA MP780 All-In-One InkJet Printer
    Genius:
  • 1,689 Answers
The manual for the unit has the steps, and illustrations.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelTechSpecsTabAct&fcategoryid=123&modelid=10444#DownloadDetailAct
Posted on Sep 09, 2009
  • 52 Answers
Open the down tray and keep paper in potrait condition and just push it back to the printer your paper will install.
Posted on Sep 08, 2009
How to make the printer regognise taht there is paper installed?
Have you tried resetting this from the print menu on your PC screen? i.e., tell your printer to loook for A4 paper. Maybe there's a miscommunication between the PC and the printer???
Jun 09, 2012 | HP PSC 2350 All-In-One InkJet Printer
I changed the printer cartages I put the paper on the tray and it took allthe paper and jamed' How do I get the paper out?
You can follow these procedure to clear the Jammed on your printer.
1.Remove the paper tray (Installing and removing the paper tray).
2.Disconnect the power from the printer dock for 5 seconds, then reconnect the power.
Carefully remove the paper if it does not automatically eject.
IMPORTANT:Check the paper slot on the back of the printer dock for jammed paper:
3.Remove the paper supply from the paper tray. Carefully "fan" the paper to keep the sheets from sticking together.
4.Reload the paper tray. Do not exceed the fill line.
5.Re-install the paper tray, then press to resume printing.
You can also check this link for other troubleshooting tips that you can do if you have problem with the printer, just click HERE.
Nov 24, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer is not running while the power cord is ok.
Epson says....
Why is the printer beeping three times and the Paper Out light is on?
This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Q: Why is the printer beeping three times and the Paper Out light is on? A: This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Sep 30, 2009 | Epson LX-300 Matrix Printer
Installing paper
The printer loads paper from the installed paper tray or the manual feed slot.
For ordinary tasks, though, you would use the paper tray. This is located in the bottom front of the printer and looks as a kind of drawer. Pull it open to feed the paper.
You can download the User's Manual for your printer from Brother:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
I am assuming you have a printer
Aug 26, 2009 | Office Equipment & Supplies
How do i install the printer paper???
i can not feed paper into printer on my calculator
Jun 23, 2009 | Canon P1-DHV Calculator
Suddenly my printer stopped printing - online and ready light will not come on - printer displays a flashing ''pc install'' how do i fix this problem? help!
From Service manual >
The printer currently has the Lower Cassette or duplexer
selected as the paper source, and has detected that the
Paper Cassette (Tray 2), which serves as a paper guide for
the Lower Cassette, is not installed. Install (reseat) the
Paper Cassette.
Apr 06, 2009 | HP LaserJet 4 plus Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
913 service motor error
If this is the first time you have seen this error, do the following:
  1. Power off the printer.
  2. Remove all installed paper trays.
  3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
  4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
  5. If everything is fine, reinstall the tray and power on the printer.
  6. Try printing a few print jobs.
  7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
  8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
  • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
  • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
    1. Put paper in tray 1 only.
    2. Print from tray 1.
    3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
    4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
    5. Power the printer back on.
    6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
      If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
      • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
      • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
    7. And if your getting the same error then you need to get it serviced...
Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Label printer is installed but will not print keeps saying it's out of paper
paper jam, or paper not in far enough to reconginze circuit pins.reset the properties of the printer to ensure it reflects proper paper size installed.
Jun 21, 2008 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
