Question about Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer 41742042100
Water is not pumped out during spin cycle
  • Anonymous May 12, 2008
    water does not pump out of the dishwasher.... pump burned out?
  • 249 Answers
The filter maybe blocked! or something caught in the pump or hose's going to it!
Posted on Dec 15, 2007
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Jun 21, 2014 | Kenmore Washing Machines
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/
Sep 01, 2009 | Kenmore Washing Machines
Kenmore washer fills during spin cycle and doesn't drain completely
HI, this is just a slight clog or faulty drain pump. check the following areas.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 18, 2009 | Kenmore Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Water not pumping out and spin cycle not working.
it sounds like you have something obstructing the pump. does the machine eventually empty? or does it remain with water in it. you need to remove the hose that leads from the tub to the pump and clear any debris. if you continue to run with debris in the pump you could burn out the pump motor
Jul 02, 2007 | Kenmore 44072 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
