Question about Electrical Supplies
I can't figure out what type of motor oil my Dyna 4500 watt generator uses?
  • 512 Answers
Straight 30 weight will be fine. 10W30 will work too.
Posted on Sep 08, 2009
My Oman generator overheats and shuts down if I plug my battery charger in and have my air conditioning on and or coffee maker
to start with with an air conditioner running (2000 +watts ) plus a coffee machine (1500 watts ) you are looking at 3500 + watts of power used from the generator
the genset has to be of a minimum of 4500 watts to run full time with out over heating
never mind what the rating says on the side, that rating is surge rated and the duty cycle is around 500 watts less than that figure
So if your gen set is 3500 watts the power is at surge power and that will overheat the genset
Of course you haven't mentioned the rating of the set , but overloading is the main reason for over heating
Jun 06, 2016 | Electrical Supplies
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
4500 running watts 5625 starting watts
http://www.manualowl.com/p/Homelite/HGCA4500/Manual/185973
Mar 23, 2015 | Watts Electrical Supplies
Champion 4500 watt generator. 140 amp ac welder Hobart, What type of oil does this need and how much
This welder generator has a Briggs & Stratton 305cc gasoline engine. The service and maintenance manual is at http://www5.briggsandstratton.com/eu/cz/pdf/owners_manual/100%5CMS3780-GB.pdf
Page two has a chart for the oil by ambient temperature ranges and whether or not you use synthetic oil.
5w30 and 10w30 synthetic are good for all temperatures. That's what I recommend.
Aug 17, 2014 | Welding Tools
Oil sae
I can not see why you want to use that oil. That would be a good oil to use if you have a lot of hours on that engine. Otherwise it is a little high on upper viscosity number unless it is running really hot and I doubt that is the case.
Jul 20, 2013 | Yamaha 4500 Watt Electric Start Generator...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Will start but will stay running
there are a couple things to check -- first check and drain the carburetor bowl,, there could be water and other contaminates inside that are not allowing the carburetor to perform correctly. this start and not stay running problem could also be caused by a bad ' governor ' . ----- BUT the problem may be also caused by a bad oil level/pressure safety switch,, check to make sure the oil is at the correct level and then check the switches to make sure they operating properly.
c...
Jan 17, 2011 | Hobart Champ 4500 Welder/Generator Outfit...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
What servicing can I do for my generator which has not been used for 2 years now YAMAHA GENERATOR EC5000DVE
change the spark plug clean the fuel tank replace filters and oil change fuel line if cracking or stiff.
remove carb bowl clean out with carb clean remove any sch-lack from old gas run and test power.
hope this helps
Aug 28, 2010 | Yamaha 4500 Watt Electric Start Generator...
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM049700 need to know what kind of oil to use and replacement sparkplug
we need to know the make of the motor....most use a SAE30 four stroke oil....not sure of the plug without knowing the make of motor.
Jul 23, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
