Question about Frigidaire Affinity ATF7000E Front Load Washer
Wash cycle dose not complete it self clothes still wet we have to run spin cycle 2 or 3 times to finish the wash
    Problem Solver:
  • 14 Answers
I would guess that the strainer before the pump is clogged. That is what happened to mine.
Posted on Sep 11, 2009
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Spin cycle
moduel or triack motor controler
Aug 12, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
My clothes are still very wet even after cycle is finished. It is like they are not fully spinning out, even when I select to do an additional spin cycle. Does anyone know why?
I'm an owner as you and do all my repair on multiple FAV6800A machines.
I don't feel from the info supplied that you have a drain pump/drain line issue because you do not take a "ND" error code for "no drain" during the wash cycle.....the wash cycle completes. I don't believe you have a stuck slightly open water inlet valve in the machine because I feel the machine would eventually over fill and flood the laundry area in time.
Is there any standing water in the wash basket when you remove the wet clothes after the final Spin Cycle?
I would place the machine in Service Mode and run it thru a Quick Spin Test (with a wet load) and record the fastest RPM speed the wash basket will spin up to.
You need the Service Manual to help you get into Service Mode to do the test. Are you going to DIY or call in repair service?
If you want to run the Quick Spin test I will look for a previous post on this forum where I called out the process steps.
Oct 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The machine will not spinn, the washing is very wet when finnished washing
clothes are wet after spinning this is due to faulty Motor coupler. test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:If it's spinning when you lift the lid, the coupler is fine.If not then the coupler is broken.It has to be replaced;.This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. ----------------------- If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn motor pulley or tub bearing. Replace the applicable component. Thanks.
Sep 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Clothes are still very wet when cycle completes.
clean the exhaut tube from the dryer to the ouside of your home
Feb 01, 2010 | Kenmore Washing Machines
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Apr 01, 2009 | Bosch Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
102 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
