I have a ten year old kp61xbr48 tv. It is in new condition. I turned it on, and my picture and sound are gone. The warm up timer light on the front continues to blink, but the unit will not go on. I unpluged the tv for ten minutes and plugged it back in to no avail. I have some electronics background. None of the fuses are blown. I found three. One was on the power supply board. The othr are probably left and right sound. I find nothing burnt, etc.. I need a sony projection monitor expert. Help !!!! Steve from Pa.
  • 3,741 Answers
The possible problem indicated by this type of blinking could be no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. most probably its faulty D board or the two ic on the d-board are gone faulty.A very common cause of this problem is the failure of one or both of a pair of ICs on the D-board. The D-board has a three or four inch black and gray component (flyback transformer) on it with a stiff/thick red wire that runs up to the tube anode and a couple of wires running to the tube neck boards. Looking from the rear, the D-board is on the left. IC8002 and IC6501 are located between the flyback and the two largest capacitors (metal cylinders) on the board. According to the service manual, there is a service position, wherein the bottom section, D-board + the rest, can be rotated up so that the bottom of the boards are accessable. This is done by lifting levers on the right and left of the chassis bracket. Your other option is to remove the board, however the connections on the flyback are very tricky and can be broken if not detached correctly.
the cost of this board is near to $400.and cost of ic is $20.first try replacing the ic by soldering machine.if still the same result the d-board needs replacement.you can get it from www.partstore.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 08, 2009
Hi. I have a samsung HLP-6163WX/XAA projection tv. Recently I asked a question, but I can't seem to add more details to it so I am asking again. After running for ten minutes the tv picture will turn black...
The glue is just protection as far as the lamp gone if you bout an after market on that probably the problem I went threw 5 of them before I to it to a TV repair shop he put in a oem lamp and it's work fine ever since hope this helps
Feb 05, 2015 | Samsung Televison & Video
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
May 16, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Sony Wega Television - Sound and no picture
If this is a LCD projection then its time for a new lamp. Have your lamp placed.
Please leave comment:
thanks
Oct 06, 2009 | Sony KP-FX532M91 TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
Fast blinking timer light and tv will not turn on
it sounds like the 1000 mfd 16vdc caps on the dm board have gone bad, but with out a model number it is hard to be sure..
Nov 29, 2007 | Televison & Video
House Fire caused by SONY kp61xbr48 T.V.
these sets are not supose to burn but sometimes do.. I would contact the manufacturer and tell them of this situation then find a lawyer.
Mar 30, 2006 | Sony KP-61XBR48 61" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
