Question about Ruud UBHC Air Conditioner
My Ruud gas furness tries to tun on but it won't...
Every things works but the the egnitor won't turn on. I checked it, there is no crack and checked it with ohm meter (shows ~ 180 ohm). For some reason, the voltage (115 V) doesn't get to the ignitor (the motor & every thing elase works fine. all the safty switches are working properly.
I think the ignitor relay is out but I can not tek which one is the ignitor switch on the control boards (there are 4-5 relay on it).
Any help is appreciated...
Buba
  • 52 Answers
If your sure you have 24 volts going to the ignitor board then the board should be replaced
Posted on Sep 11, 2009
  • 396 Answers
Replace the thermo couple.
Posted on Sep 08, 2009
Gas cap light evap code
What vehicle is it? (year, make, model, engine?) There are a lot of vacuum lines associated with the evap system on most vehicles. It could be as simple as a vacuum line cracked, broken or disconnected.
Jan 26, 2014 | 2005 Buick Terraza
RUUD 100-199 GAS WH keeps turning off
check regulator @ gas meter or bottle station is set to correct presure, may need replacing.
Oct 10, 2012 | Rheem RUUD G100-200 Water Heater,gas,100...
2005 monte carlo drl won't tun on and i have no Low beams too. High beams, turning signals and hazards works. I replaced the bulbs, still drl and low bemas don't work. Checked all fuses and th
CHECK UNDER HOOD FUSE BLOCK FOR FUSES AND CIRCUIT BREAKER AND RELAYS....IF NOT IT IS AN ELECTRICAL DIAGNOSES. USE A MULTI METER TO SEE IF YOU ARE GETTING CLOSE TO 12 VOLTS AT SOURCE!
***NO EASY FIX...ALMOST EVER!!!
Jul 30, 2012 | 2004 Chevrolet TrailBlazer
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
LEFT TURN SIGNAL DOES NOT WORK 2007 V-THUNDER VENTO
I just won't to know where I can buy parts for rear tun lights are buy replace the whole thing
Apr 14, 2010 | 2006 Vento V Thunder XL
I HAVE A RUUD SILHOUETTE GAS FURNANCE. The pilot light keeps blowing out. When I light the pilot flame it seems to work perfectly at ignition. As the Manual instructs, I hold down the ignition switch for...
Short answer, yes. However you could have another problem. Replace the thermocouple that keeps the pilot lit. You can get a universal one at any good hardware or farm store. Make sure the new thermocouple is well into the pilot flame. If the blower knocks out the pilot flame again, I would be suspecting cross contamination from a crack in the heat exchanger. As the exchanger heats up, it may be causing a small crack to open and allows the blower to extinguish the flame. It may also be causing a leak of Carbon Monoxide into the heated room air. I would get it checked out very quickly.
Mar 07, 2010 | Ruud UBHC Air Conditioner
Hi , I have a Electronic pilot lighting system on my RUUD package unit. The pilot light flame keeps blowing out or is not working properly. I removed the panel to look and see what was wrong. I could not...
Sounds like you have checked most things. A pilot will go out if it is dirty, if the gas valve is not holding or if the senser is dirty or bad. Remove the pilot and clean out the small orifice inside. Check all electrical connections, clean the sensor, and make sure the gas valve holds 24 volts on the PV side.
Nov 08, 2009 | Ruud UBHC Air Conditioner
Electric egnitor for a gas dryer lights but does not stay on
Check the following-
Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 03, 2009 | GE Dryers
GAS DRYER WON'T HEAT
you need to check to see if the egnitor is comeing on do you see a orange glow in there if not you will need to replace the ignitor
Mar 24, 2009 | Maytag Neptune MDG9700A Gas Dryer
Ruud UBHC Air Conditioner Logo
95 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
