Question about LG (GCC4521BK) CD-RW/DVD-ROM (Combo) Burner
Disk is not rotating? - LG (GCC4521BK) CD-RW/DVD-ROM (Combo) Burner
    President:
  • 2,185 Answers
If disk is not rotating, probably that the lens stopped reading and thus it stopped.
Can you do lens cleaning? If you have a lens cleaner, you can go and use it. Also, does the problem goes on even if you use other disks?
If the CD lens cleaner does not work, you might want to clean your lens manually by opening the cdrom and unscrewing the part that covers the lens. Get a soft cotton earbud damped in alcohol and rub gently on the lens. Then try playing those discs again.
If problem still persist, please let me know so that I could suggest other solutions.
Posted on Sep 08, 2009
Why is the one wheel disk and caliper very hot? on my nissan VQ 35 Rear
rotator may have been machined too much previously and the rotator is know too thin (that is the big round metal disc that the caliper squeezes onto to brake) causing the rotator to not dissapate the heat which will cause the vibration as the caliper overheats during braking.
Aug 30, 2014 | Cars & Trucks
Disk won't rotate-screen says open
A problem with the mechanism or the sensor that knows the tray position or mechanism is in the right place.
Nov 05, 2012 | Apex Digital PD-100 Portable DVD Player...
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
No disc message appear on screen
hi,
no disk messege appear because dirty optical pick up.
Open cabinet, than you will see assy loader, open it too.
There are pick up in it. Clean the lenss op pick up use tissue ( don't use wet tissue).
Check spenndle motor ( motor for rotate disk ). Rotate with finger , replace if not rotate smothly.
Good luck.
Mar 26, 2011 | Samsung DVDR120 DVD Recorder
He dont recognize the disk
Put a disc in with the label facing up and note the orientation (ie rotation) then when the disc ejects, see if it's in the same orientation (rotation). If so, the motor is not spinning the disc and it would need to be serviced.
-=/ MLF /=-
Oct 20, 2009 | Lite On Televison & Video
Disk tray stops spinning disks
You need a new laser. Thats the only fix
May 28, 2009 | Microsoft Xbox 360 Console
Changing the disc
There are two methods in changing a disk.
somewhere on the machine you will see an arrow showing you
the direction the disk travels when being used, the nut that holds the disk
on always undoes opposite to this.
normal method
unplug grinder, use the 2 spanners supplied with the grinder.
one will look like a normal spanner but thinner, this goes on the nut over the disk.
the other spanner has 2 nodules which fit in the holes on the nut under disk.
whilst holding the disk stationary with the thin spanner, rotate the noduled spanner
in the oposite direction to the disk rotation when being used.
on some models of grinder, a button on top of the grinder must be
pressed in, this stops the rotation of the disk when replacing disk.
This button performs the same function as the flat spanner.
emergency method
If you cannot find or have lost special spanner(s)
pushing the palm of your hand firmly onto the disk surface and rotating
the disk with a sudden **** in the opposite direction to that when being used
may loosen the nut. if the nut is tight hold the disk firmly and use an old
screwdriver in one of the holes and tap nut loose with a hammer on screwdriver.
last resort........if possible break the disk using pliers and remove all pieces.
putting a new disk on is opposite to method that you used to remove one.
Oct 18, 2008 | Makita 9553NB 4" Angle Grinder
LG (GCC4521BK) CD-RW/DVD-ROM (Combo) Burner Logo
111 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
