Question about TallyGenicom 2280 Matrix Printer
How do i adjust the print head gap on a tally genicon 2280+ printer
    Novelist:
  • 169 Answers
The 2280+ does NOT have a head gap leaver you can adjust the gap from with the menu on the printer.
The printer has an automatic gap adjust which should set the correct gap for most types of paper.
The print head gap can be changed in the following way;
  1. Put the printer OFFLINE
  2. Press SETUP
  3. Press the button under ADJUST on the display
  4. Press the button under HEAD
  5. You can now change the print head gap, if the Automatic Gap Agjust is working the gap setting should go from -10 to +10.
    If the Automatic Gap Adjust is not working this value will go to values smaller than -10 to larger than +10
If the Head gap will go to values less than -10 and greater than +10, first check the AGA is enabled. This can be done in the following way;
  1. Power the printer OFF
  2. Hold down the ONLINE button and power the printer ON, keep the ONLINE button held down untill the pritner has finished initializing.
  3. Press NEXT repeatedly untill you see AGA
  4. Select AGA
  5. Channge this to ALWAY or ON (cant remember!)
  6. Press SET
  7. Power the pritner OFF and back ON to exit the menu.
If the AGA option does not apear in the TEST menu above the Automatic Gap Adjust is not working and will need to be checked out.
Posted on Sep 30, 2009
    Master:
    Sergeant:
  • 460 Answers
You can adjust the head gap by lever which will be available in right side of printer.
Posted on Sep 08, 2009
How do you fix error code fault platen cal 190 on tally 6306
just clear nvram first. then in operator menu go to print gap then mode select manual then enter.
now press clear key adjust print gap by pressing + & - key together when it show 190 then decrease it to 50 and save value.
Dec 03, 2014 | Tally Office Equipment & Supplies
Hi my Tally printer giving an error Pw Sensor defekt plz advice me
You are seeing the "PW Sensor Defect Error" because the printer is detecting a fault with the Paper Width Sensor.
The Paper Width Sensor is located on the print head carriage and detects the paper edge to prevent printing on the platen.
You can check the follwoing;
  • Ensure the print head cable is not damaged and makes good contact with the printer and print head carriage
  • Ensure the Paper Width Sensor is connected correctly to the print head carriage assembly
  • It may be necessary to replace the Paper Width Sensor
Mar 09, 2011 | TallyGenicom 2280 Matrix Printer
TALLY GENICOM 2280+ HARWARE ALARM CODE +0016 +131
Unfortunatly not enough of the Hardware Alarm Task Number is included in the description to identify the most likely cause of the problem but some things you can check are;
  • Remove the ribbon from the printer, ensure this is not jammed or damaged
  • Power the printer OFF and try manually sliding the print head from side to side, look out for any objects which may obstruct the movement of the print head (pen lids etc!)
  • Ensure the print head gap is not set to close to the paper, thus jamming the print head
  • Remove the paper to ensure the paper is not restricting print head movement.
  • Clean the Optical Timing Strip that runs under the print head, ensure this is not damaged also.
  • Clean the carriage shaft, this should be FREE from any lubricants WD40 etc and dry running. Remove build up of paper dust etc.
  • Dec 06, 2010 | TallyGenicom 2280 Matrix Printer
    Hai , i have tally 2280 sprintpro printer.now it
    problem with aga gear open the printer & check the white gears situated left upper of aga motor .......
    or
    may be aga flag missing or misalinged
    Jun 29, 2010 | Tally Matrix T2280 Printer
    Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
    The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
    This may be caused buy;
    An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
    The AGA flag becoming detached from the printer or damaged
    An incorrectly fitted print head
    Fault AGA sensor.
    You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
    To disable the AGA
    Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
    When the printer displays ASCII80 ASCII136 release ONLINE
    Press NEXT until you see AGA
    Select AGA and set this to OFF
    You can then manually adjust the print head gap in the normal menu.
    Menu>Adjust>Head change the value to increase or decrease the head gap as required.
    Jul 21, 2009 | Tally Matrix T2280 Printer
    Need to set the head gap on a Genicom 3870. Lost my manual.
    If it has a manual adjust, open the top cover and on the right side will be a slide for different head adjustments, it wll be numbered 1-6, 6 being right against the paper which causes smears. Move to around 3. If it has auto adjust (you can tell this when you power up the display will show "adjusting gap" then press off line, the press program, move to head adjust, press enter, press enter again then use the arrows up and down to move to your type of printing, 2part, 3 part ect.
    Mar 13, 2009 | Tally Genicom 3810S Printer
    Tally 2280 printer givesw printhead hot error
    Is it a + version, with an Ethernet board included? These were known to cause such errors, seamingly not related at all. Try replacing the Ethernet board, or at least pull t out and disable to try.
    Feb 14, 2009 | TallyGenicom 2280 Matrix Printer
    Tally printer 6218
    May be platen gap is high check the platen gap. If the platen gap is not proper adjust it manualy.
    Aug 21, 2008 | Tally T6218 Matrix Printer
    T 2250
    tally t 2250 give hardware alam
    code +03211 ne -007000 000000 128+0304
    Jan 19, 2008 | Tally T2250 Matrix Printer
    Tally 2280
    It sounds like you may have a broken (or perhaps stuck) pin in the printhead. Check for missing dots in other letters also, or if printing a graphics object, again, a missing dot, consistent throughout the print. Other possible causes of a pin not being "fired", are a small break in the ribbon cable from the printhead to the control circuit. Look for a tiny crack or break in the ribbon, especially along the edge. Also, a defect in the electronics which control the printhead pins will cause this. If by chance the printhead is all gooped up with old ink, a pin might merely be stuck. I have taken printheads out of dot-matrix printers and soaked the pin area (area closest to the paper) in rubbing alcohol, or used Chemtronics cleaning chemicals to spray off the old sticky ink. Messy job: don't wear a clean white shirt! Lastly, if a pin is broken, either the printhead must be replaced, or sent in for repair, assuming repair centers still exist. In years gone by, I have sent in heads, and gotten them repaired successfully.
    Apr 23, 2007 | Tally Matrix T2280 Printer
    TallyGenicom 2280 Matrix Printer Logo
    660 people viewed this question
    Top TallyGenicom Office Equipment & Supplies Experts
    Kolbrun...
    Raj Patel
    Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
