Question about Microsoft Zune JS8-00001 Digital Media Player
I plug in my zune to the computer it charges the zune but I want to sync with it but nothing is happening
My wirelles not work, im heave problem
Posted on Sep 08, 2009
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
My zune will not sync
had bought a zune from a pawn shop and the zune charges but will not sync with pc. do you know what my be wrong. i loaded the software and replugged my zune but still not able for zune to sync with pc
Jul 01, 2009 | Microsoft Zune JS8-00001 Digital Media...
Nothing wont come up on my computer
Did you download the Zune software?
The Zune website has the Zune software which must be downloaded for your computer to communicate with your Zune.
And when you connect your Zune to your computer it should begin charging (as I'm assuming this is a new device).
If you have already installed the software I would assume the low battery was slowing the communication between your Zune and your computer.
If you Zune is fully charged and the software is fully installed try plugging the USB cable into a different port. Sometimes the Zune and the connector USB isn't automatically sensed on certain ports and certain moments.
Jun 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
My zune does nothing.
Try to unplug battery inside for a 15 seconds, then reconnect. Should see zune screen reappear.
Mar 19, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune wont charge at all even when its plugged in
OK this seems weird but if you have like a Nintendo Wii or a PlayStation 2 or 3 take you sync cable and plug your zune into the usb port on the system because sometimes the battery is just so dead that it dosent have enough power for the computer pick it up. mine done this a few days ago and i left it plugged into my Nintendo Wii over night and it started working again
Nov 11, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Unresponsive (and dead battery) zune o' saddness
Power sources that are supported loadTOCNode(2, 'moreinformation'); To charge the battery in your Zune device, you must connect the Zune device to one of the following supported power sources:
  • A computer’s USB port that you can connect to by using a Zune Sync Cable.
  • A Zune AC Adapter that you can connect to by using a Zune Sync Cable. Note The Zune AC Adapter is sold separately.
  • A Zune Car Charger or a Zune FM Transmitter/Charger. Note These items are sold separately.
  • An Xbox 360 console's USB port that you can connect to by using a Zune Sync Cable.
  • A “Designed for Zune” mobile battery pack
http://support.microsoft.com/kb/927348
Nov 09, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
76 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
