Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Where is the cap 5 cable located? - NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
    Problem Solver:
  • 12 Answers
Hi i am James andrew. i want to share some information to all tech engineers .its all about Eathernetpedia App.if any one want to know information of networking cables then he use this app
Posted on Jan 06, 2015
  • 512 Answers
It's CAT 5 cable and usually it comes with whatever you bought, at least one jumper cable does. What are you working on? and what is the real probelm? You can get a CAT 5 Ethernet cable at most computer stores, from a friend or off the internet. I recomend a freind as those are usually free.
Posted on Sep 08, 2009
    President:
  • 1,187 Answers
"CAT 5" = "Category 5 cable (or "Cat 5e")
Also known as Ethernet cable.
It is the cable that connects computers, switches, (some) printers, routers and other network devices together to create a "local area network" or a "workgroup" network.
The cable ends have 8-pin connectors that look like an ovsized phone cable. (Phone cables generally have 2 or 4 or 6 pins).
Latest category cable is "Cat 6"
More questions?
I hope this helps!
  • 1,272 Answers
The Question is not clear. Pls be more specific
  • 29 Answers
It's called the CAT 5 cable and it is the cable that goes from your computers Ethernet port to the router/modem/wall. Your question is very vague please be more specifc and with more detail.
How to change thermostat
The Thermostat is located under the return water hose coming from the radiator and going into the engine block.
1. disconnect the negative battery cable
2. drain the radiator fluid into a container, at least part way.
3. locate the top hose
4. you do not need to remove the hose if you can get to the blots, just remove the blots
5. gently rap the cap with a rubber, leather or brass mallet.
6. remove the thermostat, clean off all gasket material
7. install the new thermostat and new gasket
8. revers order the rest, refill the coolant, reconnect the neg batt cable.
May 04, 2015 | Cars & Trucks
Misfire
Yes, it could be the distributor cap or the ignition rotor. Best to replace both. It could also be dirty or defective fuel injectors.
Oct 03, 2014 | 2002 Chevrolet Blazer
Fuel filter location 08' volvo v50 1.8 petrol?
Removal & Installation
Print
NOTE The fuel filter is either on the left side of the firewall or next to the fuel pump near the left side of the fuel tank.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    Negative battery cable Fuel filler cap Fuel lines from the fuel filter Fuel filter from the bracket
To install:
  1. Install or connect the following:
    Fuel filter to the bracket Fuel lines to the fuel filter Fuel filler cap Negative battery cable
  2. Start the engine and check for leaks.
    Fig. Using an open end wrench to push the quick disconnect coupler sleeves back-5-cylinder models
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
To install:
    Fig. Using an open end wrench to push the quick disconnect coupler sleeves back-5 cylinder models
  1. Before servicing the vehicle, refer to the Precautions Section.
To install:
On these models, the fuel filter is part of the fuel pump assembly. Refer to Fuel Pump removal and installation.
May 12, 2012 | 2005 Volvo V50
What is the firing order for the distruburatior cap order says 1 3 5 2 4 6 this is from the motor order need from the cap
Check this for 1995 Chevrolet S10/T10 Blazer 4.3 liter V-6 VIN "W" and cofirm us...
Hope this helps (remember to rate and comment this free answer).
Aug 14, 2011 | 1995 Chevrolet Blazer
2001 dodge ram 1500 5.2 v8 van spark plug diagram
firing order is 1 8 4 3 6 5 7 2 standing in front of truck. cylinders on passenger side facing you are 2 4 6 8 cylinders on driver side facing you are 1 3 5 7 now this is your spark plugs wires location on distributor cap.with distributor facing you.2 plugs wire on cap 6 oclock position 1 plug wire on cap 8 oclock position,8 plug wire on cap 9 oclock position,4plug wire cap 10 oclock position,3 plug wire on cap 12 oclock position,6 plug wire on cap 1 oclock position, 5 plug wire on cap 3 oclock position, and 7 plug wire on cap 5 oclock position. in order for this to work you must be standing facing the engine all plug wire location on cap should be correct.
Apr 08, 2011 | Dodge Ram 1500 Cars & Trucks
My 18-55mm lense zoom bit is loose and keeps getting jammed when i try use the zoom, help?!
Brand New Nikon D90, Nikon D300, D80 For Sale.
Our PRODUCT are accompany with letter of authenticity and has 1 Year international warranty and information warranty
Please contact us for more information and purchase inquiries:
Contact: Mr roy steve
Email:camerastoreplc@hotmail.com
MSN TO CHAT:camerastoreplc@hotmail.com
Company website:www.electronicsystemltd.page.tl
Here is our price lists below
Brand new Nikon D90 :
D90 Body
18-200mm f/3.5-5.6G ED AF-S DX Zoom-Nikkor Lens,
EN-EL3e Rechargeable Li-ion Battery,
MH-18a Quick Charger,
EG-D2 Video Cable,
UC-E4 USB Cable,
AN-DC1 Strap,
BF-1A Body Cap, DK-5 Eyepiece Cap,
DK-21 Rubber Eyecup,
BM-7 LCD Monitor Cover,
Accessory Shoe Cover,
Nikon PictureProject Software,
Nikon 1 year Warranty
Brand new Nikon D80 :
D80 Body
18-55mm f/3.5-5.6G ED AF-S DX Zoom-Nikkor Lens,
EG-D2 Video Cable,
UC-E4 USB Cable,
AN-DC1 Strap,
Brand new Nikon D300
box content:
D300 digital SLR camera Body
18-200mm F/3.5-5.6G ED-IF AF DX VR Lens
Rechargeable Li-ion Battery EN-EL3e
Quick Charger MH-18a
Video Cable
USB Cable UC-E4
Strap
Body cap
Eyepiece Cap DK-5
Rubber Eyecup DK-21M
LCD monitor cover BM-6
PictureProject CD-ROM
Weight: Approx. 830g without battery, memory card, body cap, or monitor cover
WE OFFER FREE SHIPPING FOR THOSE THAT IS BUYING UP TO SIX UNITS. AT THIS TIME YOU BUY 3 ITEMS AND GET ONE FOR FREE.
Happy organisation , Happy buyers.
Thanks
Jul 13, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Camera is dead when I put battery in nothing shows on any screen. How do I troubleshoot is there A fuse or something to start with
D90 Body
EG-D2 Video Cable,
UC-E4 USB Cable,
AN-DC1 Strap,
D80 Body
EG-D2 Video Cable,
UC-E4 USB Cable,
AN-DC1 Strap,
box content:
Video Cable
USB Cable UC-E4
Strap
Body cap
Eyepiece Cap DK-5
Thanks
May 13, 2010 | Nikon D50 Digital Camera
Is theira manual way to open petrol cap on golf gti turbo mk4
look in boot space on the same side Rear fender where the fuel tank cap lid is located where the fuel tank cap is located exactly on the same side inside the boot you will find cable which unable you to operate or open the fuel tank cap lid mechanical from inside when you pull the cable it let's open the fuel tank cap from outside see for the instruction manual for more detail or just visit the nearest VW authorised service centre for hazel free driving do keep in writing for more queries
Feb 28, 2010 | 2001 Volkswagen Golf
Where are the battery connections in a 525i? I need a jumpstart and of course I cant see the battery. I see the +connect with the red cap. Where's the - black one? I lost my manual. lol
Connect red jumper cable to "jump start point"; located on passenger side of the engine, covered with a red cap marked with a +. Connect the black jumper cable to the engine block; At the most convenient point.
You can download a new owners manual at;
www.store.payloadz.com/details/108962-eBooks-Automotive-2006-BMW-5-series-525i-OWNERSMANUAL.html
FixYaWIZ...saailer
Dec 08, 2009 | 2006 BMW 5 Series
Will not turn on
You can try the following steps:
1. Disconnect all the cables from the monitor
2. Wait for 5 minutes and press the power button in the front once ( donnot connect the cables at this step)
3. Reconnect the power cable only to the monitor
4. Power on the monitor and check if you see a self test running on the screen
If the selftest feature is not running the monitor has gone bad. All dell monitor if purchased on a seprate order ,hold a 3 yr replacement warranty. If you have got the same with your dell computer, call Dell to check if its under warranty.
Thanks
proton
Nov 01, 2008 | Dell E173FP 17" LCD Monitor
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
763 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
