Question about Maytag Dryers
How do I hook a 3 wire power cord to a dryer - Maytag Dryers
  • 574 Answers
The center wire of the plug goes to the center terminal on the terminal block the two outside ones are your hot wires they go to the outside of the center one.
Posted on Sep 08, 2009
Need to hook up power cord to back of dryer
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 19, 2011 | Dryers
Tip
Electric Dryer power connections
The supply cord on an electric dryer can be 3 wire or 4 wire,
depending on the existing receptacle. All new construction
must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three
terminals. The outside terminals are for connecting the
outside wires of the cord. In a 4wire hook up, the center
terminal is for the center, insulated, white wire, the
neutral. The bare copper or green wire of the 4wire cord
gets connected above these terminals to a lug or stud on
the body of the dryer. There may be a strap there. For a
4wire cord connection this strap is connected to the stud
only.
The change for a 3wire connection is that the center green
wire of the 3wire cord connects to the center of the three
power terminals along with the grounding strap from the
dryer body above.
on May 05, 2010 | Washing Machines
I need to know which places to hook up a 3 wire dryer power cord...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Nov 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
We were recently given a kenmore dryer, without a
Here is a tip about hooking up dryer cords...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 09, 2010 | Dryers
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
4 wire power cord connection
The difference between a 3 and 4 wire cord is the 4 wire cord separates the ground and neutral, where the 3 wire grounds through the neutral. The 4 wire cord gives an extra safety against electric shock. The red and black wires on the cord go to the red and black wires on the terminal block. Then you have to determine where the green wire on the dryer goes, if it has one. Some dryers have the green wire spliced into the white wire maybe 6 inches from the terminal block. If this is the case you will hook both the green and white wires on the dryer to the nuetral (middle) terminal with just the white wire on your cord. Some dryers have a ground strap, a flat narrow peice of metal that goes from the neutral of the terminal block to the cabinet just below it. If this is the case then remove the screw securing it to the cabinet and bend it back up onto the nuetral terminal, or remove it completely. Then hook the green ground wire from the cord to the cabinet of the dryer. Make sure all of your connections are tight, but be careful not to strip them. It's also important to hook up the strain relief to prevent any possible tugs on the cord from pulling on the terminal block connections.
Jul 21, 2008 | Hotpoint Dryers
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
