Question about Nokia 6235I Cellular Phone
Headset won't turn off
How do I turn the headset off of my nokia 6235i? I have gone to settings and enhancement settings and turned it to a specific profile but even when i have a different profile on it still will not let me speak or hear and i have the headset image on my screen.
HELP
How do I get my Nokia to turn off the headset icon and be able to hear my phone the normal way? I cannot hear any incoming call with the phone speaker.( i have no earbuds!!!)
Hello there,
To turn off the headset of your phone is quite simple, what you need to do is to go to the menu of the phone, select the settings of the phone ans scroll to enhancement settings, then you select the headset profile, then you select current profile, then you go to either general profile or any other profile of choice, after selecting it, accept it and go to the home page and remove the battery of your phone without turning it off, leave it for about 5 minutes then you fix it back in and turn on the phone.
The headset settings will be turned off by now.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Nokia 6350 Cell Phone
6070 Headset symbol issue i have a Nokia 6070 and
If you still have the headset, connect it to the headset connector and remove it, do this several times and check everytime you disconnect it. If this doesn't help, please check if there's any short on the headset interface. Clean it with a soft cloth or cotton dipped in alcohol or spirit.
Your last option is to open it apart and check the headset interface internally. I would recommend you to visit a mobile repairing shop and get it repaired.
Good luck..
Thanks for using FixYa.
Jun 20, 2010 | Nokia 6070 Cellular Phone
No one can hear me. when i turn on loudspeaker it goes to headset. still can not hear me when not on speaker phone
GO TO SETTINGS, THEN SELECT ENHANCEMENTS, THEN SELECT HEADSET FOR ALL PROFILES IT WILL WORK.
Feb 12, 2010 | Nokia 6162 Cellular Phone
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
Enhancement problem
replace the enhancement connector,, it is defected, or check the contact on it
Aug 09, 2009 | Nokia 6300 Cell Phone
Connot use the headset
This is a simpleproblem you have to replace the audio connector.
May 03, 2009 | Nokia 6300 Cell Phone
110i/1112 Nokia cant activate headset option
generally wen you insert the headset pin it goes automatically to headset profile, if this is not working then go bak to the vendor & get the phones software changed
Oct 13, 2008 | Nokia 1100
Radio nokia
All know that Radio can be used only with ANTENNA......
In Mobile, that antenna feature is integrated with the enhancement,i.e, headset compatible with 5200 ......
So connect the headset before turning on the radio....
Hope this helps......
Oct 03, 2008 | Nokia 5200 Cellular Phone
Headset
try to goto Settings > Enhancements > and see the settings from there
go in Loopset > and if it is switched on, switch it off and try if the phone works as normal..
if it dsnt, i wud recommend resetting the phone should do the trick..
*#7730#
or
*#7780#
cheerz
Apr 29, 2008 | Nokia Consumer Headset
Nokia 6235I Cellular Phone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
