Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Key pad does not always open door
Key pad (6 wire pad) often works then for some unknown reason will not work for about 6 attempts then for a few days works again.
The bottom door panel is showing signs of wear, blood pressure is going up and hammer is locked in garage when needed to adjust key pad
    President:
  • 3,197 Answers
It sounds like the contacts on the keypad are going bad. A new opener with the wireless keypad is the answer.
Posted on Sep 08, 2009
Model 3585 3/4 hp prof LM- today at 4pm all 3 remotes cause 2 flashes from garage unit and no action but does with wireless keypad and wired button. Did my remote programs get jammed? No lock option.
your lock is stuck on. Sometimes a unit will go into lock mode for some unknown reason. If you have a door bell switch for a wall switch then you have to go buy a multi function L/M wall control. They're not very expensive and are easy to install.
Nov 06, 2016 | Building Materials
My Mazda 6 remote control will not reset . Everything works with the key (windows and doors). The remote has new batteries . A Mazda technisian has looked at the car,but is baffeled as to why the remo
Well I assume you disconnected the battery to the car when repairing the switch..which is electronic. Mazda systems have to be reprogrammed after power interruptions or the whole system goes crazy. There is a weird sequence of ignition turns and door closures that is required in the program sequence. You will have to try to look it up or have a dealership give or do the sequence for you.
Feb 12, 2015 | Mazda Cars & Trucks
My keypad stopped working. Is there a battery for this?
if your keypad is factory installed there is no battery . if after market yes has battery. if factory, be sure no keys are in car, when you press in a code number does the pad light up ,if yes its getting power then it is probably the keypad needs to be replaced ,if not lighting up its not getting power, check fuses and wiring connections
Dec 23, 2014 | 2005 Ford Escape Limited
Equinox radio
Possibly, the bundle that goes through the door also have speaker wires in them. Check there.
Nov 24, 2013 | Cars & Trucks
Equinox cd player
Should be no connection between the two. Those vehicles are always having problems with the radio units in them. You will either have toi get the radio fixed or find a used one at the wrecking yard but then will have to go to the dealer to get the security code done to make it work or get a after market unit. I would say go to a after market unit.
1994 Ford f250-Remote key pad won't unlock doors so opened with
You have an aftermarket alarm (factory system did not have a "valet switch") Have it removed or replaced.
Oct 24, 2009 | 1994 Ford F250 Supercab
Car won't start
Yes the imobeliser and alarm ar all part of the anti theft device. Both are either disabled with your key or a remote. If it's remote button you press then it may just need a new battery. If it's remote central locking then alway's open the door with the remote and not the key.
Aug 21, 2009 | 2001 Dodge Neon
Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Apr 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
101 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
