Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover u6437
Roll stps on all carpet levels I have tried all level adjustment to no avail. So I feel the level adjustment is not working.
    Uploaded 5 video answers.
  • 152 Answers
Belt is stretched out try belt change all the level adjustment does is pushes out little wheels on bottom up and down roller has nothing to do with level adj roller should spin regardless
Posted on Jan 06, 2008
Powerhead won't rotate on low-pile carpet
Sounds like the vacuum is adjusted too low on the carpet. Adjust it to a higher level. If this is not the problem, then the belt is slipping. Buy a new belt.
Dec 02, 2015 | Hoover Vacuums
Hoover model U6425-900 brushes do not roll
-- Make sure slide switch is in carpet position
-- The idler arn which tensions the brush belt may be broken
-- The idler arm override which is attached to the carpet slide switch may be broken
The second one is common.
Oct 30, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll...
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Oct 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
No Suction in Hoover U6450-900
If there is no suction, check the filters, if they are clean then there has to be a clog either in the hose or in the inlet down by the brush roll. See if there is suction at the hose end. If there is, then it is clogged down lower. Are you sure that the brush roll is turning when it is on the carpet? For a manual, go to, put on your model number, if one is available, you can down load it.
Jan 07, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
