Question about Sony Ericsson J100i Cellular Phone
J 100 speaker problem - Sony Ericsson J100i Cellular Phone
Pioneer vsx-454
Any speaker that can handle 100 watts or more. This receiver is rated for 100 watts per channel into an 8 ohm speaker. If the speaker is less than that, it will make the amplifier work harder and heat up faster.
May 04, 2014 | Audio Players & Recorders
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at support1@digixmedia.com or going to http://www.contelusa.net
Mar 01, 2014 | Digix BT-100 Portable Bluetooth Wireless...
How do I set pairing mode
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
Feb 04, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Audiosource amp 100 on lower volumes right speaker louder than left speaker 2.1 setup
The problem is not due to how the circuitry is configured; the problem is due to failure of some element in the right channel amplification circuit. This will require detailed troubleshooting to correct.
Dec 07, 2013 | Audio Players & Recorders
Im using my vestax vci 100 mk2 with my macs built in speakers.i am only able to hear the sound ouy of my headphones and if i choose built in speakers as an option in the set up wizard i can only hear the...
It is an either/or thing. I would recommend you get a headphone amplifier or get external speakers and drive them externally. Internal speakers are relatively poor quality anyway
Apr 28, 2011 | Vestax Vci 100 Midi Controller
My Harman Kardon Soundsticks 2 stopped working. They are plugged in, I restarted, the loudspeakers are at 100 and NOT muted, and still I can hear nothing. What do I need to do to resolve this please?
Ok, let's see if we can work this out. You say the speakers are at 100. Where are you seeing this 100? You say the speakers are NOT muted. Where are they NOT muted?
Is the light on in the sub-woofer? Is the volume turned up on the right hand speaker?
Plwase answere these and then we'll see what to do next.
Feb 06, 2011 | Harman Kardon SoundSticks II Computer...
Can only get sound through 1 channel how do i fix this problem
Open the "mixer" control on your computer.
Make sure that you have not "panned-100%-left"
or "panned-100%-right", i.e., your computer should be doing a '50/50' split of the sound into the two speakers.
Deliberately "pan" it away from 50/50, to see if putting "maximum" volume into one speaker,
and "minimum" volume into the other speaker, makes an audible difference.
Try the speakers in some other computer.
If it's still 100/zero, then the speakers are the problem.
Apr 05, 2010 | Steinberg Cubase SX3
How can I mount these on the wall?
The WS-100 is a floor standing speaker, and they are equipped with polycarbonate bases, attached right out of the box for ease of setup, providing a secure stable speaker system.For the price you paid I would not risk wall mount but if they must be eleveate I suggust a mounting shelve then the speakers ontop (shelves must hold speaker weight)
Oct 05, 2009 | Athena WS-100 Speaker
Sound qulity ?`creative t7900 ddts 100
You must balance your speakers. It is not the DDTS-100. I had the same thing with active speakers. Check your speakers separately though. If it still sounds like it sound comes from underneath the surface, the speakers are maybe broke. If not, get a new DDTS-100.
May 28, 2008 | Creative Labs DDTS-100 Digital Decoder...
Velodyne ct 100 to onkyo tx-sr705 how can i connect these two together? the correct way...
hi, on the onkyo check the speaker out , each channel has its own -ev & +ev, each speaker to its appropriate polarity, thats it, its simple.. let me know
Jan 10, 2008 | Velodyne CT-100 Speaker
Sony Ericsson J100i Cellular Phone Logo
336 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
