Question about Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
Pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
Posted on Jun 06, 2010
    President:
  • 1,723 Answers
Two things; one, the winch, even though the lever says 'free wheel' could still be getting some power. Verify with meter at winch motor.
OR; 'residual magnetism' is turning the motor slightly, without much 'real power'.
Posted on Sep 26, 2009
CAPACITY OF THE WINCH GEARMATIC MODEL B5500 ? 5500 lbs ou 5500 kgf
If its a USA mfg.. its in pounds...MAKE SURE your cable is in perfect condition!!
Jul 13, 2017 | Cars & Trucks
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
Gearmatic winch 19 on a Cat 518. Winch pulls in powerfully all the time. Lever position does nothing.
Byron: On site, Captain_Crunch said: "
  • Little band applys big band there is a toggle block at anchor point (rear of houseing) my guess is it is siezed that was our problem."
    Or, Try watching this YouTube video: https://www.youtube.com/watch?v=iZFGmWYmYnA
    May 25, 2015 | Cars & Trucks
    Was installing a winch on my 2009 prowler 700 xtx hooked positive cable to selanoid winch did not work,hooked direct to battery,works,rig wont start
    Where did you ground the winch motor? You need a separate, heavy duty, switch with a relay to transfer the positive side voltage properly... DO NOT ground to the battery..use a clean, free of paint, place to ground. You may have fried the solenoid..do not connect the positive side to the solenoid. Direct connection to the + battery from the relay is good with a good waterproof fuse in line. Sometimes I have seen the "maint. free" batteries die when used "wrong" and still show 13 volts+.
    Apr 08, 2014 | Arctic Cat 2009 Prowler 700 H1 EFI XTX 4x4
    WINCH WILL NOT RELEASE
    If reversing the lines doesn't help, see if the winch wants a bleed line, back to tank.
    Nov 27, 2013 | FINN KNIVES Marttiini Condor Timberjack...
    The winch on my 518c cable skidder wont work right !!
    I would check the hydro fluid, if you run low this may happen. also the may be a flow adjustment on the winch itself maybe an Allen fitting. Good luck
    Apr 13, 2010 | Heavy Duty Associated Equipment 6002B...
    Do i need a certain wiring harness to put a winch on my arctic cat four wheeler or just the one that comes with the winch and that on the four wheeler it self
    your artic cat may have a plug for your winch and again it may not. Call any artic cat dealer and tell them what you want to do. Have them recommend a winch that is compatable with your 4-wheeler and get a price that includes installation.
    Oct 02, 2009 | Sport & Outdoor - Others
    Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger Logo
    932 people viewed this question
    Top Heavy Duty Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Steve
    Gene Haynes
    Are you a Heavy Duty Electrical Supply Expert? Answer questions, earn points and help others
