Question about Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54)
No response from the router
My father plugged the wrong power supply into the router. (10V into a 5V)
Cracked open the case and nothing looks shot but the diode is suspected to the problem.
  • 73 Answers
If when you now plug the correct power supply in you get no lights then the router is dead. If it is in warranty then you should be OK (I wouldn't mention the 10V power supply!). If not you may find someone to repair it, but it is probably cheaper to buy a new one.
Posted on Sep 08, 2009
Open lcd 17 power supply 5volte ok 13 dimming
Hello.
First of all you need some electronic repair experiance,
You have to disconect all f the power supply that going on 5v(rgb processor in moust cases)and 13v in most cases ccfl inverter(back lite ) with his driver.than have to mesure the voltages.
-Replace the capatitors in 13v line.
if the problem persist try to replace the diode one for 13v with one for 5v,they should be the same type.and check the voltage 5v and 13v.
if the problem is still on 13v look for the problem on the 13v line.
Feb 08, 2014 | Samsung LS19CMYKF/EN Monitor
I have a seagate external hard drive. There isn't a model # on it. The part # is 9y7685-500. When I connect it the computer nothing happens. The computer doesn't recconize it. Do you have solutions? In...
You have an issue. The part number you gave is for a 12V power supply for an external hard drive. Since a typical USB puts out 5V, it cannot possibly drive your hard drive. There is a possibly..albeit low...where you can get a plug that plugs into 2 USB ports and provide 10V but I am not sure that will be enough to drive it. If this external unit is already in a case, look for a plug that would accept the power supply pin (pix attached)
413ftddsqcl-t3wyfpk5qssxovieyit11zdk-3-0.jpg Semper Fi,
Z
Feb 01, 2018 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Won't power on
Toss this junk to the garbage can, this is how I solved my frustrations with my two units
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Fuse and power supply look ok to the eye slight static sound on audio tiny flash intermitent inright corner on video, any clues? power diods check good ,nothing looks hot or burnt There is a second board...
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
Dec 09, 2009 | Audiovox FPE3206 32 in. LCD Television
Defect internal power supply DSO-142L from HP KVM. Replacement ??
Remound a universal power supply rework the internal baseplate to fit the new power supply and everything will work again
Ron W
It expert
Jul 16, 2009 | HP 336044-B21 8-port KVM Switch
Power supply fail DVE DSO-142L
The output + 5.1v/2.4 Amps and -5v/0.5Amps DC
Input is AC 100/240 VAC 50/60 Hz
Jun 05, 2009 | HP 336044-B21 8-port KVM Switch
Polaroid " 3211 TLXB red light no power up?Ive checked for Bad Caps,on the main power supply.I found none,that were swollen or leaking.It looks good.I checked volltage out to volltage inverter.all the out...
hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
Oct 12, 2008 | Polaroid 3211TLXB 32 in. LCD Television
3G compatability
Probably this could be helpfull, in case you haven't seen it.
http://carljonard.com/2008/07/how-to-charge-your-iphone-3g-in-the-car/
regards,
Konstantin
Aug 06, 2008 | Belkin Tunebase FM with ClearScan for All...
PS/2 power supply connection
You seem to have an oddball monitor if what you describe is correct. The power supply to a monitor[Display Screen is that what you mean?] is either direct to main power- in which case the power cord is either built in with a power plug for wall socket, or has a socket on the back for a separate main power cord. Or is powered from a low voltage converter that delivers low volts usually via a coaxial plug like this illustration PS2 connection does dot come into the equation as far as I know unless you have got hold of something unusual. Tell you what take a shot of the back of the monitor and lets have a look see mean while here's is a shot of a typical low voltage power supply available anywhere.
May 26, 2007 | View and View Technologies VNV AquaView...
Buffalo Technology AirStation G54 WHR-HP-G54 Wireless Router (DHWHRHPG54) Logo
172 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
