Question about PreSonus FIREPOD (673454000539) Audio Input
Operating on cubase LE4, my FireStudio Project plays for a minute and then it starts poppin and static'n...any ideas
  • 178 Answers
Check the settings of the ASIO drivers, to low on milliseconds can cause problems, also check if there are no tasks running in the background like
antivirus that can cause problems.
Disable also the screen savers.
If your using windows try also to make the page file on an other
harddrive, this reduces harddrive activity on the drive where
cubase is on, go for this to Configuration Panel\System.
Click on the tab Advanced, click on the button performance and
click in the new window on advanced, click on the button of virtual
memory.
Note that when your having alot of extended memory installed in your computer the less it needs to write to the page file, meaning less harddisk activity and more performance for audio and video aplications.
Also make shure the system is free of ad- and spyware and other unwanted software.
Succes.
Succes.
Posted on Sep 08, 2009
Hello I am trying to install CUBASE LE4 for usewith my Zoom H4n recorder but having diffultity getting the ZOOM H4 ASIO driver as mentioned in the setup guide. thanks pat
Hello Pat, you will probably have to download driver from the internet. I had a similar problem with another synthesizer software program. Even though the HD series Zooms come with cubase cds, they are not always compatible with the pcs. You should be ok after that.
Mar 23, 2011 | Computers & Internet
Crackling and popping during playback/recording, latency issues. Using Firestudio Project, Windows 7 and Cubase 5.
Turn OFF all resource hogs such as Anti-virus, Anti-pop-up, and other background programs. Disconnect all internet access such as wireless and Ethernet service programs. All these resource hogs and programs for instance that keep track of when to run scans just cause interrupts of the servicing of the high speed audio grabbers. Your machine should be BARE of all these hogs.
Feb 23, 2011 | PreSonus Firestudio 2626 26x26 + Cubase...
With my pc, the presonus firestudio tube got solid blue light but it makes audio cripples, with cubase it can't make the asio multimedia setup. i have latest driver and firmware
Check your latency settings and try something higher that what it is currently set to. 1024 samples is usually a good starting point for most newer PCs.
Feb 23, 2011 | PreSonus FireStudio Tube Audio Interface...
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
Tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Apr 05, 2010 | Tascam US-144 Sound Card
No output
Make sure you have your speakers connected to the main output. Also, in the "Universal Control" "Mixer" window, make sure that at least one of the mixes are assigner to "Mo", which stands for main output.
Feb 03, 2010 | PreSonus FIRESTUDIO Sound Card
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Get this error when I try to rewire DrumCore 2.5 to Cubase LE4
Adobe Acrobat 4 0 Full Versionplease install same version Thankinh you sir
Mar 07, 2009 | Adobe Acrobat 4.0 Full Version for PC
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Open Questions:
See all PreSonus FIREPOD (673454000539) Audio Input Questions
PreSonus FIREPOD (673454000539) Audio Input Logo
235 people viewed this question
Top PreSonus Televison & Video Experts
Are you a PreSonus Televison and Video Expert? Answer questions, earn points and help others
