Question about Craftsman Garden
Craftman 6.6 self propelled mower blowing oil between the upper &
  • bulldogchief
    bulldogchief May 11, 2010
    blowing oil...from where? Need more detail than that!
  • kevin846
    kevin846 May 11, 2010
    From where, when, which engine? If it's a Briggs and Stratton could you supply the engine model and type numbers please?
    New Friend:
  • 93 Answers
The Breather or Dip Stick Gasket at Engine. It you had the mower turned on its side befor problem, its coming out of the Muffler. This will go away but check your oil level.
Posted on Sep 14, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How much oil goes into Troy built self propelled mower
Your engine should take about 20 oz of oil to fill from empty.
Oct 23, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I HAVE A CRAFTMAN LAWN MOWER 6 HP SELF PROP RUN FOR 2 OR 3 MINUTES ONLY I CHANGE THE OIL GASOLINE AND S/PLUG CAN YOU HELP ME TO FIX IT?
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have a self-propelled walk behind number and the wheels quit spinning and the mower becomes very difficult to push. I am so frustrated. The mower has only been used five or six times and is brand new,...
I would probably take it back to where I bought it to begin with. But, I have an old Huskavara mower self propelled, at times if I set it on top of two 4 x 6 blocks (6 inches up) I have to take off the wheels and clean up the axles using thinner, degreaser, or gas, anything to break down oil or dirt. Then I oil the surfaces and reassemble, and the wheels work for a while.
Jul 04, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
How much oil should I put in my toro self propelled briggs & stratton lawn mower
if your motor doesn't have a dip stick fill the oil to the sight ring inside the fill tube, try and not overfill , this will cause seals to blow out due to increased pressuer
Jun 20, 2011 | Toro Power Lawn Mower
Oil change
Most push mowers, you just take out the filler plug and turn it on it's side to drain.Set the mower up on blocks so it rests 6-8" off the ground, place a large catch pan underneath for the oil.
Apr 09, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Sep 11, 2009 | Poulan Pro " Pro" Self Propelled Mower
I'm not sure how to start a Craftmans 6.50 lawn mower. Is their a primer button, A start button? Do I need to hold the top bar down when pulling cord? I tried the bottom bar and that just lock the cord...
Look for a red primer button/bulb and push it in slowly 3 times at the middle of it
if you do not have a primer then just hold the top bar down and pull the rope 2 or three times until it starts
check your oil first to be sure you have a safe zone reading on the dip stick before all of the above is attempted. The bottom bar maybe a self propelled engage lever which you can use after it starts.
Aug 09, 2009 | Craftsman Garden
Garden Logo
256 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
