Question about Nikon Coolpix S210 Digital Camera
LENS ERROR my lens does the same thing it just goes in and out and then says lens error and i dnt understand it cuz like i dnt hear any sand or anyhting cuz i tsake it to the beach occcasionally and its only like 6 months old. its so aggravating! and i will prolly cost more money to fix it than but a new one. SOME ONE HELP! PLZ
Lens error, len goes in and out about 3 time before the lens error screen dispay comes on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Mar 02, 2011 | Nikon COOLPIX S200 Digital Camera
S230 coolpix camera lens goes out and in at least 3 to 4 times then the lens error message appears. Any sugggestions?
Oct 31, 2010 | Nikon COOLPIX S230 Digital Camera
FEEL IN THE SAND...
This is a common problem to digital cameras for those who take it to the beach. The problem was that there could be granules of sand in the lens and thus preventing your lens to come out.
What you need to do is to hold you camera on your right hand, with the lens facing downwards. Then turn the camera on as you gently hit it with your left palm. Do this several times until the sand comes out and your lens could retract out again.
Sep 12, 2009 | Casio Exilim EX-Z57 Digital Camera
Lens won't open, & it says lens error, restart camera.
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
My Canon Power Shot A80 Digital camera goes ON but only shows the screen name Canon then the lens goes back into off - some sounds come on and then E18 shows in the lower left of a black screen. Help.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 09, 2009 | Canon PowerShot A80 Digital Camera
Camera lens is stuck in . Changed the batteries, light goes on but lens starts to come out only a fraction and stops.
Jul 05, 2009 | Cameras
My camera says lens error when i turn it on
Jun 09, 2009 | Canon PowerShot A560 Digital Camera
"LENS ERROR, RESTART CAMERA", THIS IS NOT WORKING.
Feb 20, 2009 | Canon PowerShot A540 Digital Camera
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Dec 20, 2008 | Canon PowerShot A95 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
