Question about Macally 1 Bay PHR-250CC (0701107485355) FireWire (IEEE 1394), USB 2.0 External Drive Case
Hard Drive not mounting
After upgrading the Seagate ASG model 7200 RPM 320gb hard drive in my (2.4 GHZ MacBook Pro to 500gb, I had hoped to use the existing 320 gb hard drive in an external hard drive enclosure Macally PHR-S250CC. A blue light came on, the hard drive spun, but it did not mount on any of the 3 computers I tried it on (Mac Pro, Macbook Pro, even Windows XP) (even with the additional USB power cable in case bus power wasn't enough). . I put the drive into a naked USB adapter to see if it had become damaged, etc. Worked fine.
I tried to troubleshoot, with 5 same brand same model enclosures, one from New-egg and 4 from Mac Mall. with the same results. I have three of these hard drives, Neither Hard drive can be recognized by Mac or Windows. I tried WD digital HD at last and was recognized right away. Do you think this could be a G-force problems? I would thank for any help on this.
    Brigadier General:
  • 10,406 Answers
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Posted on Sep 15, 2009
My FreeAgent GoFlex 320gb was formatted for a Mac, but I want to use it on my PC laptop. How do I get it to work?
there is your issue, if the drive is not hot swappable then you would be at no choice but to reformatt the drive for use on your pc platform.
Sep 13, 2013 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to format external hard disk on MacBook pro?
insert the externel drive into you computer..after detecting your drive by your PC...right click the drive and select format option...
May 24, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to format my new seagate freeagent 500 gb with macbook?
Here is a link to Seagate that describes how to fromat your drive fro a Mac. GOOD LUCK!
Oct 14, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate for Mac
yes you have to mac format it, this deletes all your files. use the disk utility in the utility folder an erase with mac extended
Mar 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My macbook pro does not recognized freeagent 1 TB. It sucks!!!!
You could contact Freeagent technical support at their website.
Jan 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Macally 1 Bay PHR-250CC (0701107485355) FireWire (IEEE 1394), USB 2.0 External Drive Case Logo
678 people viewed this question
Top Macally Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Paul Bade
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
