NEC 892 blocked pump
NEC 892 8 kg washing machine blocked pump, how do i unblocke it manualy
  • 26 Answers
For most blocked-pump issues, the true problem is something like a sock in the outer tub, over the tub outlet.
If the cloth has slipped into the pump hose completely, or into the pump body, you will have to remove the pump hose from the bottom of the outer tub and try to fish the material out of either the tub, the hose or the pump body. Complete removal of the pump may be necessary to accomplish this task.
For top-loaders, wherein you can't fish the clothing through the tub outlet, one can open up the unit, and remove the outer tub cover, and fish the offending bit of clothing out with a creatively-shaped length of coat hangar.
Posted on Sep 08, 2009
My NEC 892 has started banging when spinning noise. What could the problem be?
Normally just a badly loaded machine. Take all the clothes out and load them evenly around the drum for a top loader. For a front loader, take the clothes out and untangle them, lay them back in. Washing large single items like blankets or bedspreads are problematical at the best of times.
If it still persists, then my guess is that the shock absorbers or springs have broken or come adrift.
Nov 15, 2016 | Washing Machines
Washing machine blocked how do I unblock?
clean filter at the front or back of the machine will have a turn to the left insert. where the water pipe/s fit take off take top of undo the inlet valve clean out filter. tip up washer find pump you can undo this and clean housing inlets one waste one sump pipe clean and put back clean these hoses thoroughly waste pipe blow through to make sure not blocked that's it.
please rate my answer thankyou
Aug 04, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
My NEC Millennium 892 is displaying E9 and sounding alarm when I start operation. Can you tell me what this means pls. Adam Pinner
You can read up on it, its a pressure sensor,, check the connection around pressure sensor or replace it, if you can't call a repair man.
Jul 09, 2015 | Washing Machines
I have an 'nec nw452, 4.5 kg' washing machine toward the end of the cycle an OE msg comes up and the water doesnt drain. long beeps???
Check the voltage at the drain pump/valve in the first place. Look from under the washer and use a multimeter carefully in the AC range to find the voltage when the wash is initiated to the drain cycle. If there is no supply the program controller unit is faulty but if there is supply the drain pump/valve is clogged or faulty. remove clean or replace.
Feb 05, 2011 | Washing Machines
How to unblock fisher and paykel excellence smartdrive washing machine
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have an industrial 8.2 kg speedqueen washing machine and the water on completion of wash cycle is not exiting the machine. my machine is a top loader
check the pump filter first,, if its blocked up clear it out
then check that the pump is working it may just be stuck up,,,
Jul 01, 2010 | Washing Machines
NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Aug 01, 2009 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Washing Machines Logo
307 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
