Question about Brother MFC 6490CW InkJet Printer
My 240C muli-function center won't send or receive a fax
I have a Brothers 240C multi-function center, and I can not send or receive faxes, also my printer is printing at a slight angle. The fax problem started after an electrical strom and I had to replace my DSL modem. Instead of the modem it was replaced with a motorola router. I have checked all connections and everything seem to be connected. What else could possible be the problem?
Not receiving fax
You did not say if you can send a fax or not. Assuming you can not, check your wall outlet by plugging in a phone to detect a dialtone. If OK, use that phone to confirm the phone cord you use with your fax is functionnal. If OK, your fax has internal damage. If you can send a fax, verify your fax programming options. If all is OK, your fax has inernal damage and will need to be taken in for repair.
Oct 30, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
My brother printer/fax wont fax. recives a busy/no response message every time i try to fax./
This is no joke but "Very" often the number you are trying to fax to is indeed tied up for hours. Try one of the Brother free fax test numbers under"Support" on their site.
Aug 29, 2009 | Brother MFC 6490CW InkJet Printer
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
How do I change my fax number?
I found you manual to download right HERE:
- as I´m informed, you don’t need to change you FAX number, as your fax machine will receive any call on the number you connect the machine to.
5757e4d.pngdo vote, if this helped you.
regards
/Teis
Jan 16, 2009 | Brother Multi-Function Center MFC-240C...
The printer prints from the PC but will not copy without the PC
Please reset your printer to factory defaults form on screen printer menu > > >
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 6490CW InkJet Printer Logo
105 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
