Trying to get picture from laptop on tv
Hello. We are not very computer savvy. We bought a cable that connects to our laptop and tv but the picture only comes through when the computer boots up and shows the windows logo, Is there a setting that needs to be changed. We have an acer laptop and a dynex monitor replacement cable? Thank you for taking the time to help
Sincerely, confused :(
  • 140 Answers
First enter in the laptop setup, and find the video option, there you will have something like this:
onboard, extern, both (choose both)
turn off the tv.
boot up windows, right click desktop, properties, choose configuration tab, there wil be two screen, one for monitor the other for tv.
on tv side choose 640x480 (you can try higher resolutions later).
reboot and turn on tv.
worked here.
Posted on Dec 09, 2007
Connection to PC
I have had the same problem. If you have a VGA cable shown at the bottom. You can hook that into your laptop into the TV. The slots look like a blue incovering. You can also look at the image below that one for more additional help....
Jan 29, 2014 | LG RZ23LZ55 23 in. LCD Television
Hdmi audio working not video
Have you tried a different HDMI cable? Could be a lose connection in the cable.
Oct 03, 2017 | ASUS Q500A-BHI5N01 Laptop i5 2.5GHz 6GB...
Hello i have an hp pavilon dv6000 laptop and connceted to my lcd tv without any problems,3 days ago it was disconnceted and the cable was complitly out of work,i bought a new HDMI cable now,but it shows...
The first thing you can try is, connect the LCD Tv to another computer with the HDMI cable and verify it's working that way on the other pc. If it works, then the HDMI port on the Laptop might have a problem which will require Service. Troubleshooting and TIY will not fix the issue.
If the same LCD TV doesn't work on another computer, then double-check the cable and the connection. You'll be able to narrow down to the culprit and may need another LCT TV.
Is the LCD TV still working with other connections? like with your DVD Player or Cable.
Let me know the outcome.
Good luck.
Thanks for using FixYa.
Oct 27, 2010 | Computers & Internet
I have a Sony Bravia KDLV4000 and am trying to connect my laptop. I have bought a cable and am able to view the picture on the screen throught the 'PC' setting on the tv but am unsure how to get the sound...
You will need a second cable from the headphone socket on the laptop to the audio in on the tv.if it doesn't have an audio in then you need a scart to 3.5mm stereo jack lead to hear sound.
Oct 06, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
I have a Toshiba laptop L305D-S5895 and a Toshiba Hi Def LCD 37AV502U tv. I got an audio cable, that I have in the headphone spot & the original cable needed to connect the pc to the tv. I am getting all...
Which cables have you attached to your TV (the video and audio)?
Does the TV has left & right audio inputs (RCA connectors)?
When you attach a headphone to the laptop, the speakers on the laptop switch off and the sounds divert to the headphones. Try and connect a cable (stereo) from the headphone outlet on the laptop to the audio stereo inputs on the TV.
Mar 28, 2009 | Toshiba Satellite L305D-S5895 Notebook
No picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Feb 17, 2009 | Toshiba Computers & Internet
Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
Dec 29, 2008 | Gateway GM5442 PC Desktop
Problems connecting my acer laptop with tv
Sound and picture are two seperate things unless you use an HDMI cable so lets just deal with the picture first
After you do the connection, you need to tell your laptop to present the picture to the TV.
1- On your keyboard, one of your function keys (F1, F2 etc.) will have a short cut for this as a secondary functionality. Check for the function key that has an icon on it that looks like a screen (usually it is f4 or f7). Then hit the key that activates  your secondary functions and the key you just identified. This should activate the VGA output and in most cases will also give you a configruation screen (where you can select it as a secondary display, dual display etc.)
If this short cut doesnt work, you can try this
2- Make sure VGA cable is connected on both ends. Right click your desktop on the computer and select "Properties". On the new dialog, select the last tab "Settings". Click the drop down box under "Display" and you should see the TV as the secon option, select it. Then select the check box that says "Extend my display...", click Apply and OK. This should expand your screen to the TV, you should now be able to drag windows from your laptop's screen to your TV's.
Good luck! (Instructions on option 2 are for XP, if you use Vista let me know and I will look up the terminology for that)
Oct 31, 2008 | Acer Aspire 5102WLMi Notebook
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Computers & Internet Logo
410 people viewed this question
David Payne
David Payne
