Msi p4m900m2,its going shutdown after 5 minutes, and it hard to power on? the fan of processor its work
  • jeff02 Sep 08, 2009
    but when my motherboard try to remove the powersupply cable on 5v its ok, but when i attached all cable of atx powersupply, the trouble its the same, hard to power on
    President:
  • 2,022 Answers
Try to replace the cmos battery and also reset the biso by setting the jumper and remove all the cable from motherboard and see how long it works.
Posted on Sep 08, 2009
I can not download drivers for the ms 7255 msi motherboard from the msi website
The MS 7255 also known as the MSI P4M900M2-L
Here is the direct link to the MSI support page where you can download the drivers and manuals for you Motherboard.
Hope this helps! P4M900M2
Jun 19, 2014 | MSI Computers & Internet
PC get shutdown automatically
It can happen in several cases. Like:1. If your processors cooling fan does not run properly or stops running , your processor gets over heated and will automatically shutdown to prevent damage of your motherboard. In this case check this first, If is runs but not seem so smooth, just clean it- dust can jam the cooling fan.
2.If your heat sink under the cooling fan is not perfectly fit on the processor, cooling fan will not able to cool it and will result your machine shutdown!
3. In case of Bad power supply, it can also happen. Check your power supply.
4.If your machine have defected RAM or became defected, it may happen. In this case you may have blue screen with message before shutdown your machine.
5. If you have operating system of Microsoft Windows, please check your hard drive for virus. Virus can shutdown machine with a common period of time! Damaged OS which occurs often in windows operating system also can force to shutdown machine.
Please check which one is in your case. Please mention problem details like something unfamiliar for further query.
Jun 25, 2012 | AcerPower PC Desktop
When im using my computer, after 5 minutes it take a shutdown or it will be hang.
Have you checked the fans? Most desktops have a fan on the rear near the power cord thats part of the power supply, and a 2nd one on the CPU. You should feel air moving or be able to see the fans running (flashlight might be helpful). Sounds like a fan isn't running and the system gets hot after 5 min and shuts off. You should be able to remove the side cover and turn it on and see if the processor fan is running. Computer stores will have processors fans, power supply fans are usually not replaceable and you'll have to replace the whole supply.
Feb 18, 2011 | Computers & Internet
My desktop shutdown after several minutes, reboot it again but it shutdown again. reboot again but same thing happen, pc shutdown. what is the problem?
That's like stating my car was going down the road, then suddenly died. What is the problem?
Open the hood, take a look. Maybe it's something obvious.
Same thing with a computer.
1) Computer unplugged from power, open the computer case. See if the Processor fan is dirty, and the computer case fan/s.
If so use a can of compressed air for computers, and clean.
[NOTE*
BEFORE you reach inside your unplugged from power computer, observe Anti-Static Precautions ]
2) See if there are Electrolytic Capacitors on the motherboard.
Bad capacitors for the motherboard voltage regulator circuit, will cause rebooting.
How to identify bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
The motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Example;
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
3) Power Supply
Weak Voltage power rail. Caused by failing Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors)
Sep 04, 2010 | MSI Computers & Internet
Where can i download the vga driver of p4m900m2?
there is an F and L model go here and choose the correct board and you can download the driver http://www.msi.com/index.php?func=searchresult&keywords=p4m900m2
please take a moment to rate this solution thanks
robert
Nov 28, 2009 | Intel Motherboard
Sounds like the processor is going into thermal overload and the system is shutting down to keep from destroying it. Make sure your processor fan is running and that all of the ventilation vents on the bottom, back, and/or sides of your laptop are not obstructed.
Good luck and give us more detailed information about this issue for a more accurate response.
Sep 08, 2009 | Intel Motherboard
Audio driver of MSI P4M900M2 motherboard.
hello
May bee you looking for this?
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1123
choose vista or xp and download the driver.
if its wrong driver use the driver guide to get the right drivers for your motherboard.
http://global.msi.com.tw/index.php?func=downloadindex
Oct 19, 2008 | Intel Motherboard
NO DISPLAY
did you hear any beep sound, when you try to switch ON the computer..?
Thank you..
May 08, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
